05-15-2014, 11:58 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Can You explain me About your problem? Why you need dump for 16GB? if you have dead phone,You can use normal(8GB) dump in eMMC Plugin,Then Write Only Bootloader Partitions |
05-15-2014, 19:38 | #3 (permalink) |
Junior Member Join Date: Jan 2007
Member: 442234 Status: Offline Thanks Meter: 5 | after flash 4.22 dead Samsung I9070 Boot Repair Ok But No Download Mode Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I9070 V1.0.4762.51152] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM16G, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM16G, 0x000000200000 Bytes = 2.00 MB) I9070_FULL_DUMP\i9070-512M_7.28GB.BIN Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Settings Code: 0x24010E000000000000000003AB400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM16G, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM16G, 0x000000200000 Bytes = 2.00 MB) ERROR: Main data file size is less than requested to flash to main. Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! |
05-15-2014, 19:39 | #4 (permalink) | |
Member: 442234 Status: Offline Thanks Meter: 5 | Quote:
Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Settings Code: 0x24010E000000000000000003AB400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM16G, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM16G, 0x000000200000 Bytes = 2.00 MB) ERROR: Main data file size is less than requested to flash to main. | |
05-15-2014, 19:41 | #5 (permalink) |
Member: 442234 Status: Offline Thanks Meter: 5 | Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Settings Code: 0x24010E000000000000000003AB400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM16G, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM16G, 0x000000200000 Bytes = 2.00 MB) ERROR: Main data file size is less than requested to flash to main. |
