06-08-2013, 09:23 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2001 Location: IRAN Age: 49
Member: 7250 Status: Offline Sonork: 100.1575042 Thanks Meter: 440 | i use same part for i9100 and n7000 but got this error i use same chip nd part number for i9100 and n7000 but i got this error when try to restruct ... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I9100 V1.0.4843.51977] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - IGNORED! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (000000, 0x0003BA000000 Bytes = 14.91 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (000000, 0x000000080000 Bytes = 0.50 MB) No Resurrection Data is available for the eMMC Chip with Capacity = 14.91GB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000004000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000008000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000000C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000010000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000014000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000018000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000001C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000020000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000024000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000028000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000002C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000030000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000034000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000038000 is handled as Cut Excess. ERROR: Forced to Terminate. Terminated at 0x000000038000 |
06-08-2013, 10:42 | #3 (permalink) |
Freak Poster Join Date: May 2013 Location: IRAN__SHIRAZ
Member: 1933631 Status: Offline Sonork: 100.1618169 Thanks Meter: 52 | [QUOTE=gsm-lord;9486065]i think main problem is capacity of flash chip I think you have to change emmc chip But if you dont belive me you can try with another tools like trace32 ;-) Br Majidinia |
The Following User Says Thank You to ALI MAJIDINIA For This Useful Post: |
06-08-2013, 17:33 | #4 (permalink) |
Member: 7250 Status: Offline Sonork: 100.1575042 Thanks Meter: 440 | i need to know , box must know correct size of flas for repair????? why when want to use data from same size give error???? read of flash is ok and erase is ok too in dcc tab but write error |
The Following User Says Thank You to gsm-lord For This Useful Post: |
06-09-2013, 21:42 | #5 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Note: Quote:
-------------------------------------------------- Your Problem is : Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (000000, 0x0003BA000000 Bytes = 14.91 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (000000, 0x000000080000 Bytes = 0.50 MB) Can You Tell Me About Chip Part Number Also Model? Like "San--Disk SDIN4C2 16GB" or Other I Think You Have Use Older Chip for I902x or I9000 Thanks | |
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post: |
