06-11-2018, 02:08 | #1 (permalink) |
Freak Poster Join Date: Dec 2011 Location: BIRBHUM,W.B,INDIA
Member: 1707667 Status: Offline Sonork: 100.1611124 Thanks Meter: 60 | I want to write this chip,HELP Me Set I/O Voltage reads as 3.24V, SD_CLK Frequency is 2.50 MHz Memory Type .......................... eMMC Manufacturer ID ...................... 0x70 OEM/Application ID ................... 0x00 Product Name ......................... "S10004" Package .............................. BGA User Area Partition Size ............. 0x0000E4000000 Bytes (3.56 GB) Boot Partition Size .................. 0x000000400000 Bytes (4.00 MB) RPMB Partition Size .................. 0x000000400000 Bytes (4.00 MB) OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) Write Protection Bits ................ NONE ExtCSD Register Fields ............... [177] = 0x00, [179] = 0x08, [162] = 0x00 Boot Configuration ................... Boot from Boot Partition 1 (Bus Width = 1Bit) Chip Revision ........................ 0.8 Multimedia Card Revision ............. 1.7 (eMMC v5.0) Serial Number ........................ 0xA19E1A76 Memory Manufacturing Date ............ November, 2015 This emmc is in Micromax a37b handset when i tryed with flash toot it start writting but failed after some time. so i desoldered the emmc and connected to riff box. Please guide me step by step to write factory file to this emmc |
06-11-2018, 11:36 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Proper course of action is this: 1. Start JTAG Manager and download updates (eMMC plugin v4.10, JTAG Manager v1.79, RIFF Box firmware v1.50) 2. Start eMMC Plugin and click "Load layout from device" 3. Click "Load Firmware files" and select scatter file 4. Click "Write selected" This is valid only in case that MTK partition table exists in emmc (not erased) otherwise You need working full dump. |
The Following User Says Thank You to legija For This Useful Post: |
06-11-2018, 15:10 | #3 (permalink) |
Member: 1707667 Status: Offline Sonork: 100.1611124 Thanks Meter: 60 | when i load scatter file shows this . Is it normal?? Processed MTK Scatter File...OK Scatter File's Partition <PRELOADER> Cannot be Found in the Current Layout. Cannot Inject its File "preloader_hct72_wet_lca.bin" Scatter File's Partition <UBOOT> Cannot be Found in the Current Layout. Cannot Inject its File "lk.bin" Scatter File's Partition <BOOTIMG> Cannot be Found in the Current Layout. Cannot Inject its File "boot.img" Loaded Firmware File: "recovery.img" into partition: <RECOVERY> Scatter File's Partition <SEC_RO> Cannot be Found in the Current Layout. Cannot Inject its File "secro.img" Loaded Firmware File: "logo.bin" into partition: <LOGO> Scatter File's Partition <ANDROID> Cannot be Found in the Current Layout. Cannot Inject its File "system.img" WARNING: Cannot find Firmware File: "cache.img" for partition: <CACHE>. You can inject data manually. Scatter File's Partition <USRDATA> Cannot be Found in the Current Layout. Cannot Inject its File "userdata.img" Operation complete. From Scatter File were Loaded 2 partitons. Skipped 7 partitions. |
06-11-2018, 15:25 | #4 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Please click "Load layout from DEVICE" in eMMC plugin, wait for finish and then make screenshot. It looks like MTK partition table might be damaged. |
06-11-2018, 15:48 | #6 (permalink) |
Member: 1707667 Status: Offline Sonork: 100.1611124 Thanks Meter: 60 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.50 (RIFFBOX1), JTAG Manager Version: 1.79 Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 3.24V, SD_CLK Frequency is 2.50 MHz Detected eMMC Chip, ID: 0x70/0x00 (S10004), User Area Partition = 0x0000E4000000 Bytes (3.56 GB) Requested area to read overflows current memory chip's boundaries. |
06-11-2018, 16:07 | #8 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Discard all, I just found Your dump from previously read A37B. This model uses GPT style partitioning, so give us some time to check why partitions arent recognized from scatter file. |
06-11-2018, 18:18 | #12 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Ok, thank You. Even it's listed in scatter file, bmtpool is not present in flash. Best would be if You could read full dump from good phone (SP Flash tool can be used). In that case we could examine dump to know exactly if something is wrong or not. Otherwise You can simply inject partitions manually, or I can prepare image file for You. Also, please read full boot partition 1 and upload it. Please let me know if You know how to read user area full dump using SP Flash tool, or if You can read full user area from current chip using RIFF Box. |
