02-22-2012, 08:21 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: czech rep.
Member: 49095 Status: Offline Thanks Meter: 10 | HTC wildfire S - after resurrection can't flash any firmware All attemp for flashing with original shipped rom terminated in CID checking point. Please for any help, BR, Ales |
02-22-2012, 11:41 | #3 (permalink) |
Insane Poster Join Date: Mar 2010 Location: Estonia
Member: 1254144 Status: Offline Thanks Meter: 8 | Dear Sir, I have good HTC WIldfire S after resurrection by RIFF BOX same hboot 1.03.0000 and same CID I need hboot 0.90.0000 CID 11111111 Not work HTC WIldfire S DLL ? I tried reflash full flash with hboot 0.90.0000 and resurrection. same hboot 1.03.0000 and same CID I have made resurrection 10 phones month ago, all was good What's wrong HTC WIldfire S DLL? Please for any help, BR, Raiki |
02-22-2012, 12:46 | #4 (permalink) |
Member: 1254144 Status: Offline Thanks Meter: 8 | Dear aleshek, 1. Reflash HTC Wildfirw S with full flash WildFireS_Full_alive.rar by RIFF BOX - Switch to "DCC Read/Write" TAB - Select "Access ROM1 Address Space" - Check "Auto Fullflash size" - In "main" field open desired backup file - Check "Image Files use Used" - Check "Use Address as Offset for Flash Files" - Click "Write Flash" 2. Make resurrection 3. Flash with goldgard PG76IMG.zip RUU_Marvel_S_HTC_Europe_2.13.401.3_Radio_47.23c.35 .3037_7.54.39.28M_release_236989_signed.exe |
The Following User Says Thank You to raiki For This Useful Post: |
02-22-2012, 13:48 | #5 (permalink) |
Member: 1254144 Status: Offline Thanks Meter: 8 | full manual if you can't flash with goldgard after resurrection or say software is older 1. Reflash HTC Wildfirw S with full flash WildFireS_Full_alive.rar by RIFF BOX - Switch to "DCC Read/Write" TAB - Select "Access ROM1 Address Space" - Check "Auto Fullflash size" - In "main" field open desired backup file - Check "Image Files use Used" - Check "Use Address as Offset for Flash Files" - Click "Write Flash" 2. Make resurrection. after resurrection you have - HBOOT 1.03 (NOT 0.90.0000 I don't know why) - S-ON 3. read unlock code 4. Flash with goldgard PG76IMG.zip RUU_Marvel_S_HTC_Europe_2.13.401.3_Radio_47.23c.35 .3037_7.54.39.28M_release_236989_signed.exe 5. after flashing. you have android 2.3.5 - hboot 1.08.00 - s-on 6. by XTC clip - s-off - sp unlock |
02-22-2012, 17:20 | #7 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Error 140 indicates that You tried to update ROM with lower version then it's already in phone. You simply need to find newer version RUU. If for some reason You must use exact version You're trying, then You need to write SPL first, and use cooked ROM without Radio part. To unpack desired SPL from nbh image and write it to HTC phone requires some skill level, when i get some time I will prepare easy to understand manual for this. |
05-23-2012, 05:29 | #9 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: argentina
Member: 930014 Status: Offline Sonork: 1685379:ktre Thanks Meter: 84 | Quote:
regars | |
The Following User Says Thank You to ktre For This Useful Post: |
08-14-2012, 11:59 | #10 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1499565 Status: Offline Sonork: 100.1619788 Thanks Meter: 0 | Same Problem Here I have the same problem but most unfortunately I don't know what should i do exactly,specially starred part(***): 1. Reflash HTC Wildfirw S with full flash WildFireS_Full_alive.rar by RIFF BOX - Switch to "DCC Read/Write" TAB - Select "Access ROM1 Address Space" - Check "Auto Fullflash size" - In "main" field open desired backup file (***********) - Check "Image Files use Used" - Check "Use Address as Offset for Flash Files" - Click "Write Flash" 2. Make resurrection 3. Flash with goldgard PG76IMG.zip Where can I download the damn backup file.I searched everywhere. /Any information will be greatly appreciated/ |
08-14-2012, 21:59 | #11 (permalink) | |
Major Poster Join Date: Jan 2007
Member: 424642 Status: Offline Thanks Meter: 3 | Hi I just finished one wildfire s, used this method and now is working: Quote:
The Following User Says Thank You to med_ion For This Useful Post: |
10-16-2012, 07:49 | #13 (permalink) | |
No Life Poster Join Date: Feb 2007
Member: 449069 Status: Offline Thanks Meter: 61 | Quote:
My problem is i need flash this handset. can't find the desired RUU. Error 140 is returned!!! Code: marvel pvt ship s-on rh hboot - 1.09.0099 microp-0451 radio-7.57.39.10m feb 8 2012 Code: RUU_Marvel_S_hTC_Asia_India_2.13.720.1 the set is having latest firmware i guess. The problem with this set is old touch sensor broken, new one just didn't work at all. Readed on forum somewhere that we need to flash this set first in order to get new touch sensor working. Please guide on this!!! Thanks Last edited by andyvikas; 10-16-2012 at 07:58. | |
10-17-2012, 09:44 | #14 (permalink) |
Member: 449069 Status: Offline Thanks Meter: 61 | After full erase i tried resurrecting the handset. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [HTC WildfireS V1.0.4522.55486] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x55BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body...OK Resurrection complete! can someone share it!!! One more thing that i found strange is in the resurrection manual it is written Code: Resurrector will reflash radio’s boot zone and will re-write PDA’s SPL to 0.90.0000 (for NAND chips with 4Kb page size) and to 1.03.0000 (for NAND chips with 2Kb page size) versions. Mods please guide on this & please share link for Android 1.0 drivers!! Thanks |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
