01-12-2014, 08:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | I5500 & riff problem phone dead on Odin and was not recognized by PC so i used riff to repair boot but now phone is not powering and not entering download mode with key combination or with jic i write full flash using riff and phone still dead Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I5500 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x04010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK WARNING: Erasing Error (0x24) at 0x00000C440000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x00000D000000 is Ignored. Erase continues. Completed in 00:00:14.063 (Average Transfer Rate: 37281.38 kB/s) Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I5500 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! |
01-12-2014, 13:36 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Try erase full flash size Then Write I5503 or any other working dump from I5500 or Erase full flash size resurrect use "USB Jig" \This is very important for use USB+Jig....JIG Clip alone can't help |
01-13-2014, 13:50 | #3 (permalink) |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | i fixed the problem after replacing charge connector and flashing via riff this file i5500_full.bin after that phone booted and looping in android logo i made up a new USB_JIC so i flashed with boot+modem+pda+csc (i5503JPJI1_JPJI1) using multiodin 4.42 and EUROPA_v1.0.ops |
