12-01-2013, 11:41 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan Age: 41
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | i747 dad boot probilem Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I747 V1.0.5042.56958] Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. |
12-01-2013, 11:51 | #2 (permalink) |
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I747 V1.0.5042.56958] Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 3 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x07080036 ERROR: No Resurrection Data is available for the eMMC Chip with Capacity = 0B |
12-01-2013, 11:52 | #3 (permalink) |
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I747 V1.0.5042.56958] Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (000000, 0x000400000000 Bytes = 16.00 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (000000, 0x000000080000 Bytes = 0.50 MB) ERROR: No Resurrection Data is available for the eMMC Chip with Capacity = 16.00GB |
04-10-2014, 10:20 | #4 (permalink) | |
Junior Member Join Date: Mar 2013
Member: 1909321 Status: Offline Thanks Meter: 4 | Quote:
04-11-2014, 09:49 | #5 (permalink) |
Moderator Join Date: Apr 2011 Location: B.A.N.G.L.A.D.E.S.H Age: 34
Member: 1566464 Status: Offline Sonork: 100.1611207 Thanks Meter: 929 | samsung i747 repair ok , but no donwload mode Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I747 V1.0.5095.46594] Connecting to the dead body...OK Detected dead body ID: 0x706B50E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG4FB, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG4FB, 0x000000200000 Bytes = 2.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! help me |
