10-17-2014, 03:19 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | I747 p when i plug cable it show qualcom usb when i try to resurrection it saying this Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I747 V1.0.5095.46594] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. |
10-17-2014, 07:31 | #2 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | ok i manage to connect phone now but when i try to resurrection i get this error Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I747 V1.0.5095.46594] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG4FB, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG4FB, 0x000000200000 Bytes = 2.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000004150000 |
10-17-2014, 18:38 | #3 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2242829 Status: Offline Thanks Meter: 0 | RIFF JTAG Box FAQ - ERROR: Timeout while waiting for DCC Loader response. maybe you should try this? |
10-17-2014, 18:40 | #4 (permalink) | |
Member: 2242829 Status: Offline Thanks Meter: 0 | Quote:
