10-25-2014, 15:19 | #1 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1893471 Status: Offline Thanks Meter: 25 | I747 still dead after boot repair phone came to me with version 4.3 (no baseband and null imei) I tried to flash it again on 4.3 and phone became dead, I repair it with old and new but still dead and showing qualcomm in dm, pls reply and fix this issue as early as possible, and pls don't say it is hardware problem, thanks |
10-25-2014, 20:35 | #2 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: china
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | Quote:
10-26-2014, 09:19 | #3 (permalink) |
Member: 1893471 Status: Offline Thanks Meter: 25 | here are logs Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I747 V1.0.5095.46594] Connecting to the dead body...OK Detected dead body ID: 0x706B50E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0100 (016G92, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0100 (016G92, 0x000000400000 Bytes = 4.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! |
10-26-2014, 15:51 | #4 (permalink) |
Freak Poster Join Date: May 2012
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | i don't think is hardware issue the dll for i747m it is not update since January 2014 i think the dll is made for version 4.1. or 4.1.2 try to have a copy from a working phone and after inject sbl1,2,3 and tz and aboot |
10-26-2014, 16:09 | #5 (permalink) |
Member: 1893471 Status: Offline Thanks Meter: 25 | I also think that this is not hardware fault , it sounds good that dll is not updated, well waiting for team reply which enjoying sunday holiday on phone back it says I747 while I747m printed on phone's board, I also try fully restore backup i747m 4.2.2 but could not get success |
10-26-2014, 19:03 | #6 (permalink) | |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | Quote:
no update for a long time and support only from users | |
The Following User Says Thank You to nickmatine For This Useful Post: |
10-27-2014, 09:03 | #7 (permalink) | |
Member: 1893471 Status: Offline Thanks Meter: 25 | Quote:
can you teach me how to make a backup from a working phone and inject sbl 123,tz aboot? | |
10-30-2014, 15:53 | #14 (permalink) |
Member: 1893471 Status: Offline Thanks Meter: 25 | I slove issue with atf sd card 4.4.2 image, but problem is phone donot boot without sd card, I need bootloader file I747UCUFNE4 4.4.2 with pit file to flash first. late I have to install one file firmware package to boot without sdcard, If you have files or solution to this problem than pls help, really appreciate it,thanks |
