04-08-2014, 03:12 | #1 (permalink) |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | I747M Help required Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (000000, 0x000400000000 Bytes = 16.00 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (000000, 0x000000080000 Bytes = 0.50 MB) ERROR: No Resurrection Data is available for the eMMC Chip with Capacity = 16.00GB EMMC Plugin response Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I747M V1.0.5042.56972] Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x25010009000000000000000400000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (000000, 0x000400000000 Bytes = 16.00 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (000000, 0x000000080000 Bytes = 0.50 MB) Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF Completed in 00:00:00.032 (Average Transfer Rate: 65535999.97 kB/s) ERROR: Expected signature word 0x55AA, but found different. Cannot continue. Analisis is stopped. So far were found: 0 partitions. Reading FLASH1 address space from 0x000000004400 to 0x0000000045FF Completed in 00:00:00.032 (Average Transfer Rate: 65535999.97 kB/s) Reading FLASH1 address space from 0x000000080000 to 0x0000000801FF Completed in 00:00:00.047 (Average Transfer Rate: 44620255.30 kB/s) Reading FLASH1 address space from 0x000000000000 to 0x0000000003FF Completed in 00:00:00.062 (Average Transfer Rate: 33825032.24 kB/s) ERROR: Cannot find valid PIT table. |
