01-31-2013, 12:32 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 621455 Status: Offline Sonork: key4unlock Thanks Meter: 118 | I777 partition empty i have i777 which was stuck while cust updating now it shows download mode but while try to flash it stucks in factory fs i repair bot with RIFF and also did erase but it shows 15 partions empty what to do now .... Erase and Resurection ok Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Settings Code: 0x04010B000000000000000003AB400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF Completed in 00:00:00.016 (Average Transfer Rate: 131071999.94 kB/s) Reading FLASH1 address space from 0x000000004400 to 0x0000000045FF Completed in 00:00:00.016 (Average Transfer Rate: 131071999.94 kB/s) Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF Completed in 00:00:00.016 (Average Transfer Rate: 1187.50 kB/s) Reading FLASH1 address space from 0x000000004400 to 0x000000004BFF Completed in 00:00:00.016 (Average Transfer Rate: 1187.50 kB/s) Analizing the FullImage File...OK Current Phone/Image File has PIT Structure. Total quantity of listed partitions: 15 Checking which Partition is blank...COMPLETE! Following partitions are found to be completely blank: Partition: GANG at 0x000000000000 Partition: BOOT at 0x000000000000 Partition: P09 at 0x000000000000 Partition: EFS at 0x000000400000 Partition: SBL1 at 0x000001800000 Partition: SBL2 at 0x000001A00000 Partition: PARAM at 0x000001C00000 Partition: KERNEL at 0x000002400000 Partition: RECOVERY at 0x000002C00000 Partition: CACHE at 0x000003400000 Partition: MODEM at 0x000009800000 Partition: FACTORYFS at 0x00000A800000 Partition: DATAFS at 0x00002A800000 Partition: UMS at 0x0000AA800000 Partition: HIDDEN at 0x00008B000000 Thus in total, there are 15 blank partitions. |
01-31-2013, 13:10 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | You should carefully read eMMC plugin user manual: RIFF JTAG Box FAQ - How to use QUALCOMM/Exynos eMMC EFI/PIT/MBR/EBR Partitioning plugin You havent actually read any partition content, You just obtained partition table from device. |
The Following 2 Users Say Thank You to legija For This Useful Post: |
01-31-2013, 23:35 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Your eMMC Have a Bad Block in Some Where...So,You Need Cut Bad Block,Then edit .PIT file(if have),Then Repartition and reflash Hang on FactoryFS Usually is Mean Bad Block |
