12-19-2013, 08:34 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Indonesia Age: 41
Member: 584778 Status: Offline Thanks Meter: 78 | I8160 Resurrection Error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I8160 V1.0.4705.16807] Connecting to the dead body...OK Detected dead body ID: 0x00300012 - WRONG!!! ERROR: Current ID does not belong to the Samsung I8160 family. give me solution please..........:con fused: |
12-26-2013, 06:09 | #4 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: skyw0rk jombang
Member: 239081 Status: Offline Thanks Meter: 253 | Quote:
meybe dll is broken..sory sir if im wrong... i was try resuraction...and succes.. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I8160 V1.0.4705.16807] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x0000EC000000 Bytes = 3.69 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000000100000 Bytes = 1.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 3.69GB Flashing the dead body...OK Resurrection complete! | |
12-26-2013, 13:53 | #5 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote: I'm here -- This is not real ID for I8160 "0x00300012 " so you have bad soldering jtag wires or have bad MCU -- Please try remove all jtag wires solder carefully connect usb to phone insert battrey and pess resurrection key thanks | |
01-03-2014, 03:14 | #6 (permalink) | |
Member: 584778 Status: Offline Thanks Meter: 78 | Quote:
so you have bad soldering jtag wires or have bad MCU what is the meaning ?? i used JIG X-Fbus II no wire jumper | |
01-06-2014, 18:05 | #7 (permalink) | |
please send me link dump i8160 sirr...............: confused: | |
