12-29-2011, 21:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: inside iPhone Age: 50
Member: 26011 Status: Offline Thanks Meter: 38 | i9000 Error i got following error while repairing Analyzt Jtag Chain Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.29, JTAG Manager Version: 1.38 Selected Resurrector: [Samsung i9100] Connecting to the target...OK Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4BA00477, IR Length = 0x04 bits Total IR length: 0x0004 bits and i try to Resurrection and get following error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.29, JTAG Manager Version: 1.38 Selected Resurrector: [Samsung i9100] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. any one can help me what should be this problem. Thanks. |
12-29-2011, 23:27 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | select rtck sample at max and don't use usb....just hold power on key during resurrect...offcorse use full charge battery |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
12-30-2011, 09:10 | #3 (permalink) |
Member: 26011 Status: Offline Thanks Meter: 38 | Hi Babak Nuri, Thank you very much for your Tips. i have success. and first i try to to Resurrect without USB and power switch while flashing power sw was disconnected. another 2-3 attempt also same thing happen. then i try to do this way, while resurrect i connect the charger to phone and it was success. LOG. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.29, JTAG Manager Version: 1.38 Selected Resurrector: [Samsung i9100] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 10 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x03AB400000 Bytes) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0000080000 Bytes) Flashing the dead body...OK Resurrection complete! |
12-30-2011, 10:24 | #4 (permalink) |
Member: 26011 Status: Offline Thanks Meter: 38 | @ Babak Nuri. by the way can you reply here bro http://forum.gsmhosting.com/vbb/f634...7/#post8029591 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
