11-14-2011, 15:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Iran Age: 36
Member: 103435 Status: Offline Thanks Meter: 49 | I9000 Repair problem with rifff itried with riff [11/14/2011 1:51:02 AM] [START OPERATION_ID = RESURRECT] [11/14/2011 1:51:24 AM] Open serial port...OK [11/14/2011 1:51:24 AM] Connecting to the RIFF Box...OK [11/14/2011 1:51:24 AM] Firmware Version: 1.28, JTAG Manager Version: 1.37 [11/14/2011 1:51:24 AM] Selected Resurrector: [Samsung I9000] [11/14/2011 1:51:24 AM] [11/14/2011 1:51:24 AM] Connecting to the dead body...OK [11/14/2011 1:51:24 AM] Detected dead body ID: 0x1BA00477 - CORRECT! [11/14/2011 1:51:24 AM] Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz [11/14/2011 1:51:24 AM] [11/14/2011 1:51:24 AM] Resurrection sequence started. [11/14/2011 1:51:24 AM] Establish communication with the phone...OK [11/14/2011 1:51:24 AM] Initializing internal hardware configuration...OK [11/14/2011 1:51:24 AM] Uploading resurrector data into memory...OK [11/14/2011 1:51:24 AM] Starting communication with resurrector...OK [11/14/2011 1:51:24 AM] [11/14/2011 1:51:24 AM] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) [11/14/2011 1:51:24 AM] Flashing the dead body...OK [11/14/2011 1:51:24 AM] Resurrection complete! [11/14/2011 1:51:24 AM] [FINISH OPERATION_ID = RESURRECT] then i download full_work_DL_mode.bin and wrote to my phone [11/14/2011 2:25:56 AM] [START OPERATION_ID = DCC_WRITE_MEMORY] [11/14/2011 2:25:56 AM] [11/14/2011 2:25:56 AM] Current Settings: [11/14/2011 2:25:56 AM] ----------------- [11/14/2011 2:25:56 AM] Address: 0000000000 [11/14/2011 2:25:56 AM] Length: 0000000000 [11/14/2011 2:25:56 AM] Address Space: ROM1 [11/14/2011 2:25:56 AM] AutoFullFlash: CHECKED [11/14/2011 2:25:56 AM] Use End Address: UNCHECKED [11/14/2011 2:25:56 AM] ECC Module Enabled: UNCHECKED [11/14/2011 2:25:56 AM] Image File is Used: CHECKED [11/14/2011 2:25:56 AM] Use Address as Offset: CHECKED [11/14/2011 2:25:56 AM] Main (CHECKED): C:\Users\Kasra Mobile\Desktop\I9000 J-tag\full_work_DL_mode.bin [11/14/2011 2:25:56 AM] Redu (CHECKED): [11/14/2011 2:25:56 AM] [11/14/2011 3:21:55 AM] Open serial port...OK [11/14/2011 3:21:55 AM] Connecting to the RIFF Box...OK [11/14/2011 3:21:55 AM] Firmware Version: 1.28, JTAG Manager Version: 1.37 [11/14/2011 3:21:55 AM] Selected Resurrector: [Samsung I9000] [11/14/2011 3:21:55 AM] [11/14/2011 3:21:55 AM] Connecting to the dead body...OK [11/14/2011 3:21:55 AM] Detected dead body ID: 0x1BA00477 - CORRECT! [11/14/2011 3:21:55 AM] Set I/O Voltage reads as 2.81V, TCK Frequency is 12 MHz [11/14/2011 3:21:55 AM] Settings Code: 0x000E010000000000000000000067 [11/14/2011 3:21:55 AM] [11/14/2011 3:21:55 AM] Resurrection sequence started. [11/14/2011 3:21:55 AM] Establish communication with the phone...OK [11/14/2011 3:21:55 AM] Initializing internal hardware configuration...OK [11/14/2011 3:21:55 AM] Uploading resurrector data into memory...OK [11/14/2011 3:21:55 AM] Starting communication with resurrector...OK [11/14/2011 3:21:55 AM] [11/14/2011 3:21:55 AM] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) [11/14/2011 3:21:55 AM] [11/14/2011 3:21:55 AM] Writting FLASH1 memory from 0x0000000000 to 0x001FFFFFFF [11/14/2011 3:21:55 AM] Completed in 00:55:57.048 (Average 6:31 AM 11/14/2011Transfer Rate: 161.06 kB/s) [11/14/2011 3:21:55 AM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] after that my phone restart on S logo then i flash my phone with ODIN3_v1 with I9000XXJPU frimware and know my phone turned on but still the same problem no baseband....... Legiga can u help for solution? |
11-14-2011, 15:57 | #2 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | After that just root your phone and rebuild the imei with Spt box or z3x. P.S : What is the imei like, Is it showing imei 00000 or no imei. |
The Following User Says Thank You to CDMA_RASHID For This Useful Post: |
11-14-2011, 16:39 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | not hard work just download sdk and copy tool folder to c: start cmd and follow step cd C:\Program Files\Android\android-sdk\tools adb shell "mkdir /sdcard/efs" adb shell su mv /efs/.nv_data.bak /efs/.nv_data.bakk mv /efs/.nv_data.bak.md5 /efs/.nv_data.bakk.md5 rm /efs/nv_data.bin rm /efs/nv_data.bin.md5 rm /efs/.nv2.bak rm /efs/.nv2.bak.md5 busybox cp /sdcard/efs/nv_data.bin /efs/nv_data.bin chmod 755 /efs/nv_data.bin chown radio.radio /efs/nv_data.bin adb shell su rm /efs/.nv_data.bakk rm /efs/.nv_data.bakk.md5 busybox cp /efs/nv_data.bin /efs/.nv_data.bak busybox cp /efs/nv_data.bin.md5 /efs/.nv_data.bak.md5 chown radio.radio /efs/.nv_data.bak chown radio.radio /efs/.nv_data.bak.md5 |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
11-14-2011, 16:43 | #5 (permalink) | |
Member: 103435 Status: Offline Thanks Meter: 49 | Quote:
11-14-2011, 16:47 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | first flash with 2.2 root phone copy working nv_data.bin to sdcard - from working phone - try adb ........................up post flash modem firmware pathed by z3x....... repair own imei by z3x |
11-17-2011, 08:56 | #10 (permalink) |
Member: 103435 Status: Offline Thanks Meter: 49 | I tried but everytime stuck on Checking NV Data... Incorrect File Writing NV Data To Phone... OK Searching Samsung USB Modem...Not Found Done with Samsung Tool ver 11.3 & then i search the forum and found that BABAK NURI has similar problem on this post http://forum.gsmhosting.com/vbb/f453...i-efs-1363849/ can u share how u fix this problem Babak? |
11-17-2011, 11:00 | #11 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
yes,right..but i fix it.. just try spt method and write own imei with 2gtools-35.00.29 with z3x... all-tool-11.3or4 can't help you first flash with 2.2 firmware like XXJPK and root with superoneclick and run adb method made by spt sec = flash I9000_XXJPK_modem_patched and repair imei with 2g-tools by z3x or add me on sonorok 100.1606847 | |
11-17-2011, 21:20 | #14 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | sorry this is my wrong.. use 3g-tools9.4 by z3x for repair imei |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
