05-01-2012, 03:11 | #1 (permalink) |
No Life Poster Join Date: May 2002 Location: Canada Age: 97
Member: 12270 Status: Offline Thanks Meter: 107 | i9000m dump failing...please help Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9000 V1.00] Connecting to the dead body... ERROR: Set I/O Voltage to 2.80V failed. Real reading is 2.46V Now I know what many will say, check connection and I have used these jigs in the past to resurrect with no problem. Connection is good but for some reason I cannot read dump. I am running XP, service pack 3 with new RIFF drivers. I choose the DCC Read/Write tab and choose Samsung galaxy i9000with JTAG TCK set to 8 mhz. Also I choose Auto FullFlash Size and set address 0x0000 0000 0000 and length to 0x0002 0000 0000. I choose Access ROM1 Address Space. For power I have used original 100% charged battery and as well DC power supply set from 3.6 to 4.4 volts. For the life in me I cannot get it to recognize the board. The board is not dead and turns on fine but has PIN enabled so my goal is to read dump to gain access of PIN. Can someone tell me what I am doing wrong. I have done everything even soldering wires directly but cannot read phone. Any help would be appreciated. BR |
05-02-2012, 23:25 | #4 (permalink) | |||
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi ERROR: Set I/O Voltage to"value" failed. Real reading is "value". Quote:
To properly diagnose root of the problem, do the following: Disconnect ribbon cable from RIFF Box and press any function button. In case that box internal I/O voltage generator is malfucntioning, You'll receive same error: Quote:
In case that box is okay, error will be gone: Quote:
05-02-2012, 23:35 | #5 (permalink) |
Member: 12270 Status: Offline Thanks Meter: 107 | Yes, you are correct. With no cable attached I still have; Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9000 V1.00] Connecting to the dead body... ERROR: Set I/O Voltage to 2.80V failed. Real reading is 3.28V So I guess my box's internal I/O voltage generator is malfunctioning and need to buy new box? Thank you for your response! When I unplug USB and restart RIFF and press any button with no cable attach I get: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9000 V1.00] Connecting to the dead body...FAILED None is detected. |
05-03-2012, 00:22 | #7 (permalink) |
Member: 12270 Status: Offline Thanks Meter: 107 | Thanks but as I mentioned in my first post I need to dump my own phone as I want to retrieve the PIN from the phone without erasing data. Thanks though for your reply. |
05-03-2012, 00:37 | #8 (permalink) |
Member: 12270 Status: Offline Thanks Meter: 107 | I have an update. I have on hand another i9000 board and a T959 which both share the same jtag pinout. I tried both boards and they all have the same I/O error so after some troubleshooting with different jigs, cables, computers, etc. I have come to he conclusion it's likely a faulty box. I will order a new box tonight and when I get it I'll try again. Thanks for all your help. Best Regards |
05-04-2012, 17:59 | #10 (permalink) |
Junior Member Join Date: Oct 2009 Location: HONDURAS
Member: 1143060 Status: Offline Sonork: 100.1609341 Thanks Meter: 2 | hello I have the arhivo full_read_dump_i9000m as flashing on the phone hello I have the arhivo full_read_dump_i9000m as flashing on the phone what is the procedure to flash it |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
