07-27-2013, 11:29 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Philippines
Member: 351593 Status: Offline Thanks Meter: 41 | i9003 cant repair.....help Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9003 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 100 kHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: Memory at given address cannot be Written. how ca i solve this..... i used rps i used original battery same results... set 5khz to higher but same resuts pls help |
07-27-2013, 22:47 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You Can't Repair I9003 With " 5 / 100 200 KHZ You Need Use I9003_IRAM.dll Set Speed At MAX TCK Or Set Speed At 6MHZ Thanks |
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post: |
