07-18-2013, 14:26 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: in your Heart
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | i9003 connection error tried many times connecting it but it always gives following error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I9003 V1.00] Connecting to the dead body...ERROR Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK ERROR: The RTCK Signal does not respond. resoldered wires many times and tried but cannot connect where ami going wrong please ????????? |
07-18-2013, 20:43 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Plz use lower speed like 6MHZ at TCK ,Also Please use I9003_IRAM.dll - But if you want sure about soldered wires,You can goto "Jtag Read/Write" Page,Then Set Speed at 5 kHz on TCK.,,,Then Press "Analize Jtag Chain" And See Result |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
07-19-2013, 06:56 | #3 (permalink) | |
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | Quote:
on analyze jtag chain it give following error: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49936] Connecting to the target...ERROR Set I/O Voltage reads as 1.80V, TCK Frequency is 5 kHz None is detected. is it soldered wires error or something else thanks for the reply | |
07-19-2013, 08:48 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Yes,This is Soldering Wires or Power Or HW Damage Problem Because if your phone is in sleep mode,Analize chain must detect at "FFFFFFF" ID.Also your phone is On ,so must be detect real ID --- So,Plz Check Jtag Wires and input usb to phone also use power supply |
08-08-2013, 15:51 | #5 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: somewhere in the world Age: 34
Member: 666294 Status: Offline Thanks Meter: 19 | Quote:
Connecting to the target...OK Set I/O Voltage reads as 2.60V, TCK Frequency is 5 kHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0xFFFFFFFE, IR Length = 0x06 bits Total IR length: 0x0006 bits what would be problem sir..? | |
12-17-2013, 13:43 | #6 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1217562 Status: Offline Thanks Meter: 10 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49936] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0xFFFFFFFE, IR Length = 0x06 bits Total IR length: 0x0006 bits help me plzzzzzz |
