06-29-2013, 07:57 | #1 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1964282 Status: Offline Thanks Meter: 3 | i9003 dead after write dcc [ SOLVED ] before phone conected ok,after wrtite efs with make partition file dump imei 04xxx..... but baseband unkonwn,i try to write full dump failed phone can recoverd n now always asking driver 4640 how can i found driver |
The Following User Says Thank You to eko_2222 For This Useful Post: |
06-29-2013, 11:17 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Try Resurrect Phone. 1-make SD_Magic 2-Resurrect Phone 3-Reflash Phone With .Pit File and 4parts Firmware Check Imei and BB Rewrite org imei Via Other Tools |
07-06-2013, 06:04 | #3 (permalink) |
Member: 1964282 Status: Offline Thanks Meter: 3 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49936] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0xFFFFFFFE, IR Length = 0x06 bits Total IR length: 0x0006 bits with Analyze but if coneced n get id Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9003 V1.00] Connecting to the dead body...ERROR Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK None is detected. |
07-06-2013, 11:16 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I'm Sure You Forget See This : "1-make SD_Magic" |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
