06-09-2013, 08:46 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | I9003 efs write-still unknown baseband and imei-help? Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x22010000000000080000000000A80000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Writting FLASH1 memory from 0x000000080000 to 0x000000AFFFFF Completed in 00:00:26.109 (Average Transfer Rate: 424.68 kB/s what i do as a next step? is it hardware? helppp meeeeeeeeeeee |
06-09-2013, 12:04 | #2 (permalink) | |
No Life Poster Join Date: Apr 2008 Age: 28
Member: 745672 Status: Offline Thanks Meter: 556 | Quote:
@ zone3 imei null or blank ? after repair efs problm same now try to flash with full dump file if not solved then check in hardware its can be hardware | |
06-09-2013, 21:04 | #5 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
if after Write EFS Imei Still "Null"....This is HW Problem For Write Dump You need Read : RIFF JTAG Box FAQ - JTAG Manager - DCC Read/Write TAB | |
06-10-2013, 04:31 | #6 (permalink) | |
Member: 946381 Status: Offline Thanks Meter: 150 | Quote:
