07-07-2013, 12:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | i9003 full flashed-still imei and baseband unknown-help Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I9003 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x27010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF Completed in 00:47:48.328 (Average Transfer Rate: 188.50 kB/s) so i think hardware-which ic? i have dead i9003.can i replace from it? |
07-08-2013, 08:29 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Yes,if you still have a problem with imei/bb ,you need check HW Yes,You Can use from another dead pcb RF and BB Chip usually need replace |
