12-30-2013, 07:32 | #1 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 619957 Status: Offline Thanks Meter: 50 | i9003 resurrection done but not write dump here is images of error and resurrection |
12-30-2013, 11:03 | #2 (permalink) |
Member: 619957 Status: Offline Thanks Meter: 50 | respected riff team and supporters now writing dump file but always stop on 14% with recover error and failed i try with 2 different dump files and wit and without magic card both but always now give this error and if i ignore this section now dump write full but set is not working and it is in dead condition Last edited by gulab; 12-30-2013 at 11:11. |
01-01-2014, 11:35 | #4 (permalink) |
Member: 619957 Status: Offline Thanks Meter: 50 | dear friends if this problem is impossible than anyone tell me then i return this set to customer and if any member or friend know about this problem then pl,ssssssssssssssss guide me where i am wrong and what is the real problem with me |
01-01-2014, 13:32 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Just Need Select "Ignore" and "Remember" -- But if you have any problem with I9003,This is Best Solution: 1-Erase Full Flash Size 2-Create SD_Magic and Insert to Phone 3-Select "I9003_IRAM" From List 4-Press Resurrect And Select "Germlin Zone" and Start 5-Check Phone For DL-Mode By "USB+JIG and Power Supply" Enjoy |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
01-01-2014, 15:23 | #6 (permalink) | |
Member: 619957 Status: Offline Thanks Meter: 50 | Quote:
pl,s explain me sir | |
01-01-2014, 16:19 | #7 (permalink) | |
pl,s tell me step by step procedure | |
01-02-2014, 08:40 | #8 (permalink) | |
Member: 619957 Status: Offline Thanks Meter: 50 | thanks Quote:
01-02-2014, 12:41 | #9 (permalink) | |
01-02-2014, 14:16 | #10 (permalink) | |
Member: 619957 Status: Offline Thanks Meter: 50 | pl,ss help Quote:
01-03-2014, 16:40 | #12 (permalink) |
Member: 619957 Status: Offline Thanks Meter: 50 | thanks to all of my friends with the help of riff team and some of forum friends i realive my i9003 and now no problem its working fine i recover it via riff with hard strugle but the upper error is comes because my home button not working i find out this after when my set working ok now all ok again thx to all so if any i 9003 have if this problem pl,s check vol down and home key also and then try for download mode |
01-03-2014, 16:40 | #13 (permalink) |
