04-09-2012, 20:08 | #421 (permalink) |
Freak Poster Join Date: Jun 2004
Member: 70463 Status: Offline Thanks Meter: 6 | two solution l've just made with this problem. 1# is without replacing internal memory just to work the phone via 2gb phone memory.this solution is tried and tested also work with i9003 on almost 18 units. 2# is by replacing it... and it works both phone and internal memory.... br,sanflora |
04-09-2012, 21:14 | #422 (permalink) |
Insane Poster Join Date: Apr 2007 Location: mother Serbia Age: 38
Member: 488048 Status: Offline Thanks Meter: 57 | waste of time, just change internal memory it is very easy... if you do not have time or if you are not sure what are you doing sent them to Serbia. |
04-12-2012, 08:40 | #423 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1724643 Status: Offline Thanks Meter: 1 | samsung I9003 not connecting to Riff please help me How to connect? error log given in Attached picture[/COLOR] [/B][/COLOR][/SIZE] Last edited by legija; 04-12-2012 at 09:58. |
04-12-2012, 09:57 | #426 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | You need to Magic card to be inserted in sd card slot on phone. So, first create magic card, insert it in phone, then connect power to phone and start resurrection. Without magic card phone will not be detected. |
The Following User Says Thank You to legija For This Useful Post: |
04-12-2012, 18:41 | #427 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | error RTCK Quote:
I got same problem trying to slove dead s7330 by z3x The problem is that pin 1 not gnd the pin 8 is gnd so you have to turne image to oposit side if you see image from left to write you must solder wires from write to left Thats' it | |
04-13-2012, 23:50 | #428 (permalink) | ||
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
I9003-dll work perfectly just read again..: : Quote:
04-17-2012, 15:43 | #432 (permalink) |
Insane Poster Join Date: Dec 2011
Member: 1699596 Status: Offline Sonork: 100.1604372 Thanks Meter: 9 | SAM i9003 Success by Riff Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.41 Selected Resurrector: [Samsung I9003 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! |
04-17-2012, 17:48 | #433 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Spain
Member: 702604 Status: Offline Thanks Meter: 12 | Hi!! After try and try and try............Finally I have repaired it,jtag manager give an error in the final at 99%,but the phone can do in download mode,now phone is OK. Thanks sires. |
04-17-2012, 18:34 | #434 (permalink) | |
You can press resurrect again and select "continue" for resume write Of Corse you can use this option for all model also all operation like "Read/Write dump" | |
04-17-2012, 18:38 | #435 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Thank's For Report ,But No Need Open New Thread You Can Post Repair Log in http://forum.gsmhosting.com/vbb/f634...-jtag-1049341/ Thread |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
I have 5.28 unlocker by cable. | GreEn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 15 | 07-13-2000 21:57 |
5.28 working solution by eeprom 24x16 | SLO/EU | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-22-2000 15:55 |
nokia nse-spv8 by zulea | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-12-2000 07:52 |
have nokia lock 2 solution by cable | oskarcore | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:49 |
