Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 04-09-2012, 20:08   #421 (permalink)
Member: 70463
Thanks Meter: 6
@unlockflash
two solution l've just made with this problem.
1# is without replacing internal memory
just to work the phone via 2gb phone memory.this solution is tried and tested also work with i9003 on almost 18 units.
2# is by replacing it...
and it works both phone and internal memory....
br,sanflora
Old 04-09-2012, 21:14   #422 (permalink)
Member: 488048
Thanks Meter: 57
waste of time, just change internal memory it is very easy...
if you do not have time or if you are not sure what are you doing sent them to Serbia.
Old 04-12-2012, 08:40   #423 (permalink)
Member: 1724643
samsung I9003 not connecting to Riff
please help me How to connect? error log given in Attached picture[/COLOR]
[/B][/COLOR][/SIZE]
Old 04-12-2012, 09:17   #424 (permalink)
Member: 476075
Sonork: na
Thanks Meter: 40
which cable you used. did u soldering on board? if yes then it does not work. make modification 3gs headset flex and use. 100% works.
br
Old 04-12-2012, 09:40   #425 (permalink)
Member: 1724643
yes i soldered on Board
Old 04-12-2012, 09:57   #426 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
You need to Magic card to be inserted in sd card slot on phone.
So, first create magic card, insert it in phone, then connect power to phone and start resurrection.
Without magic card phone will not be detected.
The Following User Says Thank You to legija For This Useful Post:
Old 04-12-2012, 18:41   #427 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 280
error RTCK
[/B][/COLOR][/SIZE]
Hi bro.
I got same problem trying to slove dead s7330 by z3x
The problem is that pin 1 not gnd the pin 8 is gnd so you have to turne image to oposit side
if you see image from left to write you must solder wires from write to left
Thats' it
Old 04-13-2012, 23:50   #428 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Originally Posted by ramoon20 View Post
Hi bro.
Thats' it
It's not same .....
I9003-dll work perfectly
just read again..:
Mr.Legija:
Old 04-16-2012, 19:04   #429 (permalink)
Member: 702604
Thanks Meter: 12
Help repair i9003 with OMAP3630
Hi all!!
It's possible to repair samsung i9003 with omap3630?If yes,how I can do?
Thanks for all help..
Old 04-16-2012, 19:57   #430 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 820
check this link
http://forum.gsmhosting.com/vbb/f634/i9003-successfully-repaired-riff-jtag-screenshots-1372316/index4.html#post7841142
Old 04-16-2012, 20:40   #431 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Please Read "Resurrection Help"
Old 04-17-2012, 15:43   #432 (permalink)
Member: 1699596
Sonork: 100.1604372
Thanks Meter: 9
SAM i9003 Success by Riff
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.32, JTAG Manager Version: 1.41
Selected Resurrector: [Samsung I9003 V1.00]
Connecting to the dead body...OK
Detected dead body ID: 0x0B6D602F - CORRECT!
Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
Flashing the dead body...OK
Resurrection complete!
Old 04-17-2012, 17:48   #433 (permalink)
Member: 702604
Thanks Meter: 12
Hi!!
After try and try and try............Finally I have repaired it,jtag manager give an error in the final at 99%,but the phone can do in download mode,now phone is OK.
Thanks sires.
Old 04-17-2012, 18:34   #434 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Originally Posted by arthur1964 View Post
Hi!!
Thanks sires.
Hi
You can press resurrect again and select "continue" for resume write
Of Corse you can use this option for all model also all operation like "Read/Write dump"
Old 04-17-2012, 18:38   #435 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Thank's For Report ,But No Need Open New Thread
You Can Post Repair Log in http://forum.gsmhosting.com/vbb/f634...-jtag-1049341/ Thread
The Following User Says Thank You to BABAK NURI For This Useful Post:
I have 5.28 unlocker by cable. GreEn Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 15 07-13-2000 21:57
5.28 working solution by eeprom 24x16 SLO/EU Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-22-2000 15:55
nokia nse-spv8 by zulea rothmanns Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-12-2000 07:52
have nokia lock 2 solution by cable oskarcore Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-29-1999 22:49
Page generated in 0.44890 seconds with 10 queries
