04-17-2011, 22:21 | #1 (permalink) |
Crazy Poster Join Date: Apr 2011 Location: Israel
Member: 1558132 Status: Offline Thanks Meter: 2 | Samsung i9023 nexus s dead after worng flash need help |
05-10-2011, 19:23 | #6 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1501506 Status: Offline Thanks Meter: 47 | RIFF Box GT-i9020 Support Ok so I'm aware that the RIFF box now supports GT-i9023 Nexus S which the European non-carrier base SLCD phone. However, I have multiple GT-i9020 T-Mobile Nexus S phones coming my way and I'm wondering if the resurrector has been tested or can be used on the GT-i9020. If anyone knows the answer that would be great! Thanks! |
05-14-2011, 20:49 | #13 (permalink) |
Member: 1501506 Status: Offline Thanks Meter: 47 | Update! The GT-i9020 is capable of BRICK REPAIR with the Riff box as well! Just solder the points and flash both the bootloader and recovery under the resurrection option. Be sure to make a full backup of the phone first though just in case. Also, you will need an adjustable power supply as opposed to using the battery or atleast I did. RIFF kept on picking up over 3.2 volts when it needed 2.8V with the battery. With a lot of tweaking, I was able to get the board down to the 2.80 volts it was looking for and it worked perfect. When finished, put the phone into download mode using a JIG and then flash the appropriate firmware. [5/14/2011 1:19:02 PM] [START OPERATION_ID = DCC_READ_MEMORY] [5/14/2011 1:24:25 PM] Open serial port...OK [5/14/2011 1:24:25 PM] Connecting to the RIFF Box...OK [5/14/2011 1:24:25 PM] Firmware Version: 1.23, JTAG Manager Version: 1.32 [5/14/2011 1:24:25 PM] Selected Resurrector: [Samsung I9023] [5/14/2011 1:24:25 PM] [5/14/2011 1:24:25 PM] Connecting to the dead body...OK [5/14/2011 1:24:25 PM] Detected dead body ID: 0x1BA00477 - CORRECT! [5/14/2011 1:24:25 PM] Set I/O Voltage reads as 2.83V, TCK Frequency is 18 MHz [5/14/2011 1:24:25 PM] [5/14/2011 1:24:25 PM] Resurrection sequence started. [5/14/2011 1:24:25 PM] Establish communication with the phone...OK [5/14/2011 1:24:25 PM] Initializing internal hardware configuration...OK [5/14/2011 1:24:25 PM] Uploading resurrector data into memory...OK [5/14/2011 1:24:25 PM] Starting communication with resurrector...OK [5/14/2011 1:24:25 PM] [5/14/2011 1:24:25 PM] Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB) [5/14/2011 1:24:25 PM] [5/14/2011 1:24:25 PM] Reading FLASH1 address space from 0x00000000 to 0x1FFFFFFF [5/14/2011 1:24:25 PM] Completed in 00:05:19.115 (Average Transfer Rate: 1694.29 kB/s) [5/14/2011 1:24:25 PM] [FINISH OPERATION_ID = DCC_READ_MEMORY] [5/14/2011 1:24:59 PM] [START OPERATION_ID = RESURRECT] [5/14/2011 1:26:49 PM] Open serial port...OK [5/14/2011 1:26:49 PM] Connecting to the RIFF Box...OK [5/14/2011 1:26:49 PM] Firmware Version: 1.23, JTAG Manager Version: 1.32 [5/14/2011 1:26:49 PM] Selected Resurrector: [Samsung I9023] [5/14/2011 1:26:49 PM] [5/14/2011 1:26:49 PM] Connecting to the dead body...OK [5/14/2011 1:26:49 PM] Detected dead body ID: 0x1BA00477 - CORRECT! [5/14/2011 1:26:49 PM] Set I/O Voltage reads as 2.83V, TCK Frequency is 18 MHz [5/14/2011 1:26:49 PM] [5/14/2011 1:26:49 PM] Resurrection sequence started. [5/14/2011 1:26:49 PM] Establish communication with the phone...OK [5/14/2011 1:26:49 PM] Initializing internal hardware configuration...OK [5/14/2011 1:26:49 PM] Uploading resurrector data into memory...OK [5/14/2011 1:26:49 PM] Starting communication with resurrector...OK [5/14/2011 1:26:49 PM] [5/14/2011 1:26:49 PM] Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB) [5/14/2011 1:26:49 PM] [5/14/2011 1:26:49 PM] Flashing the dead body...OK [5/14/2011 1:26:49 PM] Resurrection complete! [5/14/2011 1:26:49 PM] [FINISH OPERATION_ID = RESURRECT] |
05-24-2011, 05:22 | #14 (permalink) |
Member: 1501506 Status: Offline Thanks Meter: 47 | Another update, I have successfully resurrected both the GT-i9020T and GT-i9020A. I just wanted people to know that both are dead boot fixable with the RIFF box. Just flash the bootloader AND recovery and you can get back into download mode, and then flash with ODIN. |
The Following User Says Thank You to connexion2005 For This Useful Post: |
06-27-2011, 05:49 | #15 (permalink) |
Junior Member Join Date: May 2011
Member: 1573423 Status: Offline Thanks Meter: 0 | Samsung I9023. How to repair IMEI? Hi all! After repairing bricked phone Samsung I9023 with Riff box IMEI was lost and it is shown as Unknown in the Settings menu. Also Baseband version is shown as Unknown, though in Fastboot mode Baseband version is shown correctly as I9020XXKD1. So, my questions: What could happen? What should I do to repair lost IMEI? Any advices very appreciated. Thanks in advance. |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
