-   RIFFBOX (http://forum.gsmhosting.com/vbb/f634/)
-   -   i9023 NEXUS S Boot Repair Problem (http://forum.gsmhosting.com/vbb/f634/i9023-nexus-s-boot-repair-problem-1298135/)
daniel_mm 04-17-2011 22:21
Samsung i9023 nexus s dead after worng flash need help
hello to all . i have samsung nexus s i9023 . and i have a big Problem i Mistakenly flash incorrect rom With odin for i9020 . and now the phone is dead not respond i have a jig that need to put the phone in download moode bat is not work the phone is complet dead need your help thenk for all can help
Athelcute 04-18-2011 04:54
reflash again ur problem solved
daniel_mm 04-18-2011 12:19
i can the phone not power on + i have RIFF JTAG BOX if its can halp me i like to know
legija 04-18-2011 13:26
Hi,
Please register Sonork account, and PM me Your ID.
We have working backup from this phone and will contact You for further tests.
Thank You.
Vitalich 05-10-2011 11:58
Hi Daniel,
Do you have any progress with your i9023?
I have absolutely the same problem, and now don't know what to do. :confused:
Any advices will be appreciated.
Thanks in advance.
connexion2005 05-10-2011 19:23
RIFF Box GT-i9020 Support
Ok so I'm aware that the RIFF box now supports GT-i9023 Nexus S which the European non-carrier base SLCD phone. However, I have multiple GT-i9020 T-Mobile Nexus S phones coming my way and I'm wondering if the resurrector has been tested or can be used on the GT-i9020.
If anyone knows the answer that would be great!
Thanks!
reddragon_bruno 05-10-2011 19:44
If you want, you can test after making a full backup of your phone first. That way you can test without breaking your phone more...
connexion2005 05-10-2011 20:06
Good point and that is definitely the plan. Will the Samsung partitioning tool work in this scenario does anyone know?
legija 05-10-2011 20:17
Just make full backup, You dont need to use partition tool in this case.
reddragon_bruno 05-10-2011 23:03
I think he wanted to know if this plugin works with i9020 backups. Do you think it could??
connexion2005 05-11-2011 20:32
Hi Legija,
Have you happened to test with GT-i9020 yet?
legija 05-11-2011 22:56
As i know those are same phones -,))
connexion2005 05-14-2011 20:49
Update! The GT-i9020 is capable of BRICK REPAIR with the Riff box as well! Just solder the points and flash both the bootloader and recovery under the resurrection option. Be sure to make a full backup of the phone first though just in case.
Also, you will need an adjustable power supply as opposed to using the battery or atleast I did. RIFF kept on picking up over 3.2 volts when it needed 2.8V with the battery. With a lot of tweaking, I was able to get the board down to the 2.80 volts it was looking for and it worked perfect. When finished, put the phone into download mode using a JIG and then flash the appropriate firmware.
[5/14/2011 1:19:02 PM] [START OPERATION_ID = DCC_READ_MEMORY]
[5/14/2011 1:24:25 PM] Open serial port...OK
[5/14/2011 1:24:25 PM] Connecting to the RIFF Box...OK
[5/14/2011 1:24:25 PM] Firmware Version: 1.23, JTAG Manager Version: 1.32
[5/14/2011 1:24:25 PM] Selected Resurrector: [Samsung I9023]
[5/14/2011 1:24:25 PM] Connecting to the dead body...OK
[5/14/2011 1:24:25 PM] Detected dead body ID: 0x1BA00477 - CORRECT!
[5/14/2011 1:24:25 PM] Set I/O Voltage reads as 2.83V, TCK Frequency is 18 MHz
[5/14/2011 1:24:25 PM] Resurrection sequence started.
[5/14/2011 1:24:25 PM] Establish communication with the phone...OK
[5/14/2011 1:24:25 PM] Initializing internal hardware configuration...OK
[5/14/2011 1:24:25 PM] Uploading resurrector data into memory...OK
[5/14/2011 1:24:25 PM] Starting communication with resurrector...OK
[5/14/2011 1:24:25 PM] Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB)
[5/14/2011 1:24:25 PM] Reading FLASH1 address space from 0x00000000 to 0x1FFFFFFF
[5/14/2011 1:24:25 PM] Completed in 00:05:19.115 (Average Transfer Rate: 1694.29 kB/s)
[5/14/2011 1:24:25 PM] [FINISH OPERATION_ID = DCC_READ_MEMORY]
[5/14/2011 1:24:59 PM] [START OPERATION_ID = RESURRECT]
[5/14/2011 1:26:49 PM] Open serial port...OK
[5/14/2011 1:26:49 PM] Connecting to the RIFF Box...OK
[5/14/2011 1:26:49 PM] Firmware Version: 1.23, JTAG Manager Version: 1.32
[5/14/2011 1:26:49 PM] Selected Resurrector: [Samsung I9023]
[5/14/2011 1:26:49 PM] Connecting to the dead body...OK
[5/14/2011 1:26:49 PM] Detected dead body ID: 0x1BA00477 - CORRECT!
[5/14/2011 1:26:49 PM] Set I/O Voltage reads as 2.83V, TCK Frequency is 18 MHz
[5/14/2011 1:26:49 PM] Resurrection sequence started.
[5/14/2011 1:26:49 PM] Establish communication with the phone...OK
[5/14/2011 1:26:49 PM] Initializing internal hardware configuration...OK
[5/14/2011 1:26:49 PM] Uploading resurrector data into memory...OK
[5/14/2011 1:26:49 PM] Starting communication with resurrector...OK
[5/14/2011 1:26:49 PM] Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB)
[5/14/2011 1:26:49 PM] Flashing the dead body...OK
[5/14/2011 1:26:49 PM] Resurrection complete!
[5/14/2011 1:26:49 PM] [FINISH OPERATION_ID = RESURRECT]
connexion2005 05-24-2011 05:22
Another update, I have successfully resurrected both the GT-i9020T and GT-i9020A. I just wanted people to know that both are dead boot fixable with the RIFF box. Just flash the bootloader AND recovery and you can get back into download mode, and then flash with ODIN.
Vitalich 06-27-2011 05:49
Samsung I9023. How to repair IMEI?
Hi all!
After repairing bricked phone Samsung I9023 with Riff box IMEI was lost and it is shown as Unknown in the Settings menu. :(
Also Baseband version is shown as Unknown, though in Fastboot mode Baseband version is shown correctly as I9020XXKD1.
So, my questions:
What could happen?
What should I do to repair lost IMEI?
Any advices very appreciated.
Thanks in advance.
Page generated in 0.28239 seconds with 5 queries
