You sure?Becuase i repaired many S devices....no problem with any one... some case needed replace eMMC,and some case just need resurrect Anyway,if later time you have a bricked phone,please contact me via sonork.. |
nexus i9250 helps you remove the battery when it no longer turns on and does not boot, the computer does not recognize it, and riff and ort I have no solution. |
samsung anycall m200 i have samsung anycall m200 its dead via upgrade board same like i9023 i select i9023 and restruct but still on same position phone dead bricked help plz thnx |
i have also one same problem bro plz help me/.. |
yes, very correct request but in this matter the supporter always in silent. thank u. for very good request with good citation. |
Hi Why not look at "Riff-Tracker"....? Dump file already in tracker --- Any way,,,Usually no need write dump file.. Resurrector can repair phone...So,if phone can't turn on,Or hang on logo,You Need Replace new chip(eMMC) |
I9023 dead boot not done with RIFF ... I was trying to unlock bootloader of this I9023 after that phone is totaly dead (no downlload mode) i had do ressurection with or without option (recovery , gremlin) the soft says Resurrection complete! but result is black screen and the 2 butons lights , i had erase flash and resurrecte it again but same result ... any solution to this probleme or any one have a full dump of i9023 cause this file not aviable in the support or in riff tracker Quote:
Hi I'll add dump file in ftp..So,i think maybe add this file to riff-tracker for 1 or 2 days later But,if you need for now,i can upload again in any where , like hotfile or rapidshare |
Try with other tools. |
Yes i need the dump urgently now ... |
Where are u BABAK NURI ??????????????? |
Sorry i have not see it , i will try both dumps and post result ... |
I had tryed 4 dumps and do resurction with and without recovery and gremlin option but it dont work the only new think after erase and write dump is that computer detect the phone as (S5PC110) , and i found a tutorial written to repair I9023 when its detected like that but u need Linux (ubentu) but the customer take his phone . I also tryed to repair phone with 2 other jtag boxes but no luck , the only box i had not try with it is Medusa . here is the link for the tutorial : xda-developers - View Single Post - [SOLVED] Really "bricked" Nexus S after bad update |
