11-28-2012, 14:22 | #196 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Samsung I9020T Resurrection Problem.Please help me. |
11-29-2012, 04:45 | #197 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You Have 2 Option For I902x ---- (Downloadin) Hold Both Vol Key ,Then Put USB Cable...( No Need Press Power On Key) And (Fastboot Mode) Hold Vol Up ,Then Press "Power On Key" --- You Can Flash Your Phone Via "Odin"...Need "Downloading" Or You Can Flash Your Phone Via Fastboot Method ----- in next post,please use normal font... ---- Quote:
11-29-2012, 07:09 | #198 (permalink) |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Thank you for your reply and sorry for that format.Next time I will use default format.With your suggestion I was resurrection I9020T Handset successfully by selecting that option.But after that resurrection complete also my handset is not getting download mode.I was try to put download mode by pressing Volume+ and Volume- and connect the usb cable.Handset is power on and just Google logo is came and hang on on that logo.That all.Now please tell me how to put this handset into download mode? |
11-29-2012, 07:53 | #199 (permalink) |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Can you please tell me What is Gremlin zone?In which cases this Option is checked?I mean which cases this is used?I was resurrect by selected tick mark in that option.I did not select recovery option in select Areas to flash.Is this process correct? |
12-11-2012, 08:42 | #205 (permalink) | |
Insane Poster Join Date: Jul 2007
Member: 538559 Status: Offline Thanks Meter: 6 | Quote:
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9020A V1.0.4724.8865] Connecting to the target...OK Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x1BA00477, IR Length = 0x40 bits Total IR length: 0x0040 bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x1BA00477: Samsung S5PC110 2. 0x1BA00477: Generic CORTEX-A8 | |
12-11-2012, 08:43 | #206 (permalink) |
Member: 538559 Status: Offline Thanks Meter: 6 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9020A V1.0.4724.8865] Connecting to the dead body...ERROR Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz None is detected. |
12-11-2012, 11:00 | #207 (permalink) |
Member: 538559 Status: Offline Thanks Meter: 6 | but other box support Update ORT JTAG - Samsung SHW M200 Repair Dead Boot ! |
12-11-2012, 13:32 | #208 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | Quote:
maybe u need to hold power button , also use power supply , and use usb cable , check connections, for me repair boot ok but no power no download mode, | |
12-12-2012, 06:56 | #210 (permalink) |
Junior Member Join Date: Oct 2006 Location: hyderabad Age: 40
Member: 381462 Status: Offline Sonork: 100.1650981 Thanks Meter: 2 | can u help me ,wr eMMC chip is located on pcb. i hv same prblm ,after resuerrection phne stil in black screen. no download mode.when tried to keep just serach n menu buttons light thnks in advnce |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
