Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 07-23-2011, 12:44   #31 (permalink)
Member: 906499
Sonork: sen-i
Thanks Meter: 47
Originally Posted by Little_Master View Post
I have used jig .. but no work
Just recently , I have successfully Flashed phone with Z3x Box.
But
Now, phone is stuck on GOOGLE Screen with Opened Locked LOGO..
DOn't know how to revive it from this stage.
Thanks to RIFF , to make phone able to flash
LITTLE MASTER
need fullflash man help me
Old 07-24-2011, 03:18   #32 (permalink)
Little_Master's Avatar
Member: 1205146
Thanks Meter: 858
Flash File link is in my post
downlaod that , it worked for me
LITTLE MASTER
Old 07-24-2011, 18:09   #33 (permalink)
Member: 906499
Sonork: sen-i
Thanks Meter: 47
LITTLE MASTER
no it will not work by me , becouse my nv_data damage , no wi-fi , no bluetooth adresse , error android if it is on , need fullflash that can read and write only riff . odin multioloader does not flash it . plz read fullflash with riff from your phone and give it me , plz
Old 07-25-2011, 20:59   #34 (permalink)
Member: 906499
Sonork: sen-i
Thanks Meter: 47
if you have problem you say legija help , but if enother people need your help - you dont help
Old 08-04-2011, 16:28   #35 (permalink)
Member: 906499
Sonork: sen-i
Thanks Meter: 47
hi team , have paid entoher i9023 make fullflash from it and flashed my i9020T , and it not help , no imei .
can anz body help me?
Old 08-09-2011, 09:50   #36 (permalink)
Member: 1573423
SPT box can help you.
Old 11-02-2011, 09:33   #37 (permalink)
Fune4u's Avatar
Member: 278548
Sonork: 100.1583183
Thanks Meter: 941
Plezz Add i9020
Plezz sir Add i9020 google nexus s dade boot raper
Old 11-02-2011, 10:46   #38 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,163
i9020 = i9023, already tested and confirmed.
Old 11-04-2011, 12:26   #39 (permalink)
Member: 246443
Hello! sorry, i bad know language))
Plz, help ) samsung i9023 dead after flashing...
Riff box resurection- ok, but black screen...
download mode- ok (but, BLACK SCREEN, samsung modem-ok)
flashing with odin3 -ok, but phone not pwr on(
flashing with z3x -ok, phone not pwr on...
may be you have fullflash on this model?
in this topic i9023 NEXUS S Boot Repair Problem
little master- writen, that phone pwr on- after flashing with z3x, but my phone not show logo google(
Old 11-17-2011, 23:35   #40 (permalink)
Member: 1112020
Thanks Meter: 11
Plz i9020 dead flashing, error repair like i9023 :(
i have a i9020 dead by flash, I try repair boot like i9023, but appears this error, maybe somebody with experience will help me...
[16/11/2011 16:22:59] [START OPERATION_ID = DCC_ERASE_MEMORY]
[16/11/2011 16:23:01] Open serial port...OK
[16/11/2011 16:23:01] Connecting to the RIFF Box...OK
[16/11/2011 16:23:01] Firmware Version: 1.28, JTAG Manager Version: 1.29
[16/11/2011 16:23:01] Selected Resurrector: [Samsung I9023]
[16/11/2011 16:23:01] Connecting to the dead body...OK
[16/11/2011 16:23:01] Detected dead body ID: 0x1BA00477 - CORRECT!
[16/11/2011 16:23:01] Set I/O Voltage reads as 2.79V, TCK Frequency is RTCK
[16/11/2011 16:23:01] Adaptive Clocking RTCK Sampling is: [Sample at MAX]
[16/11/2011 16:23:01] Resurrection sequence started.
[16/11/2011 16:23:01] Establish communication with the phone...OK
[16/11/2011 16:23:01] Initializing internal hardware configuration...OK
[16/11/2011 16:23:01] Uploading resurrector data into memory...FAILED
[16/11/2011 16:23:01] ERROR: RAM memory selftest failed.
[16/11/2011 16:23:01] [FINISH OPERATION_ID = DCC_ERASE_MEMORY]
[15/11/2011 13:18:11] Open serial port...OK
[15/11/2011 13:18:11] Connecting to the RIFF Box...OK
[15/11/2011 13:18:11] Firmware Version: 1.27, JTAG Manager Version: 1.29
[15/11/2011 13:18:11] Selected Resurrector: [Samsung I9023]
[15/11/2011 13:18:11] Connecting to the dead body...OK
[15/11/2011 13:18:11] Detected dead body ID: 0x1BA00477 - CORRECT!
[15/11/2011 13:18:11] Set I/O Voltage reads as 2.79V, TCK Frequency is 800 kHz
[15/11/2011 13:18:11] Resurrection sequence started.
[15/11/2011 13:18:11] Establish communication with the phone...OK
[15/11/2011 13:18:11] Initializing internal hardware configuration...FAILED
[15/11/2011 13:18:11] ERROR: Read/Write memory failed during H/W Init.
Old 11-18-2011, 11:30   #41 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,413
set rtck 4 or 6mhz
power key hold during resurrect
use usb
and make sure not HW problem
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 11-19-2011, 02:53   #42 (permalink)
Member: 1691560
Sonork: peterock168
But
LITTLE MASTER
I have same problem
I tried with and without Gremlin Option ,, and With and Without Recovery Selection ..
But Phones still on blackscreen. Only two lights comes on bottom keypad.
But I only have RIFF BOX and do not have Z3x Box. now my phone can goto "download mode" with blacksreen + two lights.
But fail to use odin to recovery.
Please can help ...
Old 11-19-2011, 04:48   #43 (permalink)
Member: 1691560
Sonork: peterock168
Originally Posted by peterock168 View Post
I have same problem
Please can help ...
odin fail at the end of flashing CSC files (when using abnormal "download mode" with blacksreen + two lights.)
my i9023 phone still no display.
pls can some one help me !!!
Old 11-19-2011, 14:34   #44 (permalink)
Member: 781426
Thanks Meter: 16
samsung i9023 deadboot help riffbox
i have samsung i9023 deadboot i do all the tricks that i know then follow also this thread
http://forum.gsmhosting.com/vbb/f634/i9023-nexus-s-boot-repair-problem-1298135/
but still black screen with 2 lights
what i need 2 do? help me riff box team
Old 11-20-2011, 05:23   #45 (permalink)
INTERNATIONAL's Avatar
Member: 726409
Thanks Meter: 33
samsung i9023 phone lock i try will be jtag box phone is dead how to solutions
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 18:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.45768 seconds with 9 queries
