01-27-2012, 08:10 | #77 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | I still can't file full dump so maybe this is answer. http://forum.gsmhosting.com/vbb/f665...ml#post8028114 |
01-28-2012, 10:25 | #78 (permalink) |
Freak Poster Join Date: May 2008 Location: SINGAPORE Age: 40
Member: 781426 Status: Offline Thanks Meter: 17 | i agree with this, any progress on how we can solve this problem using riff box |
The Following User Says Thank You to makoto28 For This Useful Post: |
02-02-2012, 09:13 | #79 (permalink) |
Freak Poster Join Date: Apr 2005 Location: india Age: 40
Member: 135518 Status: Offline Sonork: 1605927:cellcomna Thanks Meter: 56 | i9023 sir i have i9023 without imei in my z3x phone dosn,t connect on modem mode i restrucat with riff after phone only showing keyped light fisrt right 2 second left side what i do its very urget thanks |
02-02-2012, 15:51 | #82 (permalink) |
Member: 135518 Status: Offline Sonork: 1605927:cellcomna Thanks Meter: 56 | sir i have i9023 without imei in my z3x phone dosn,t connect on modem mode i restrucat with riff after phone only showing keyped light fisrt right 2 second left side what i do its very urget thanks |
02-02-2012, 23:20 | #83 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | i9023 with riff 3x time ı try always black LCD after ı try with medusa phone LCD ok.. Riff boot after odin firmware with CSC always fail... After medusa without fail all OK Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [Samsung I9023] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK WARNING: Programming Error (0x24) at 0x00010C0000 is handled as Cut Excess. Resurrection complete! MEDUSA LOG Selected device model: Samsung GT-I9023 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 1BA00477, IR Length = 4. MI: Halting target, attempt 1. MI: ARM CoreSight DAP detected. MI: CPUID = 43110222. JTAG speed : 12000 KHz. VREF level : 2.74 V CPU : Samsung S5PC110 Core ID : 1BA00477 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9023_Re pair.mf" file... Writting BOOT section. Please wait... Done Writting UPCH section. Please wait... Done Disconnected <ID:0/004> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Bootloader_I9023XXKA3.tar.md5 is valid. <OSM> PDA_SOJU_GRJ22_TMO_EUR_MR2_SIGNED.tar.md5 is valid. <OSM> MODEM_I9023XXKD1_REV_00_CL990283_SIGNED.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/004> Odin v.3 engine (ID:4).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/004> Removed!! <ID:0/004> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Bootloader_I9023XXKA3.tar.md5 is valid. <OSM> PDA_SOJU_GRJ22_TMO_EUR_MR2_SIGNED.tar.md5 is valid. <OSM> MODEM_I9023XXKD1_REV_00_CL990283_SIGNED.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/004> Odin v.3 engine (ID:4).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> bootloader.img <ID:0/004> NAND Write Start!! <ID:0/004> boot.img <ID:0/004> recovery.img <ID:0/004> system.img <ID:0/004> userdata.img <ID:0/004> radio.xx.img <ID:0/004> Transmission Complete.. <ID:0/004> Now Writing.. Please wait about 2 minutes <ID:0/004> Receive Response form LOKE <ID:0/004> dgs.img <ID:0/004> <ID:0/004> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/004> Removed!! <ID:0/004> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Bootloader_I9023XXKA3.tar.md5 is valid. <OSM> PDA_SOJU_GRJ22_TMO_EUR_MR2_SIGNED.tar.md5 is valid. <OSM> MODEM_I9023XXKD1_REV_00_CL990283_SIGNED.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/004> Odin v.3 engine (ID:4).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> bootloader.img <ID:0/004> NAND Write Start!! <ID:0/004> boot.img <ID:0/004> recovery.img <ID:0/004> system.img <ID:0/004> userdata.img <ID:0/004> radio.xx.img <ID:0/004> Transmission Complete.. <ID:0/004> Now Writing.. Please wait about 2 minutes <ID:0/004> Receive Response form LOKE <ID:0/004> dgs.img <ID:0/004> RQT_CLOSE !! <ID:0/004> RES OK !! <ID:0/004> Completed.. <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/004> Removed!! medusa repiar lcd in minutes we must have all jtag boxs |
The Following User Says Thank You to BesTCooL For This Useful Post: |
02-04-2012, 18:29 | #84 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 39
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | samsung i9020a is support I have a samsung i9020a boot that has died and I wonder if this supported for repair? |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
