04-26-2012, 15:27 | #121 (permalink) | |
Junior Member Join Date: Mar 2008 Location: Brazil
Member: 735686 Status: Offline Thanks Meter: 3 | Quote:
Friend, I need a Full Flash it, you could do? thanks, br | |
05-07-2012, 09:05 | #123 (permalink) |
Freak Poster Join Date: Apr 2005 Location: india Age: 40
Member: 135518 Status: Offline Sonork: 1605927:cellcomna Thanks Meter: 56 | after flash with i9020-23 test firmware flash with spt after flash with uart cable write easyily imei 10000000% thanks riff team and spt team w.b.r |
05-07-2012, 14:01 | #124 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | i9020t bricked i have i9020t samsung dead via flashing recovery now i restruct this phone selecting i9023 after restur phone on bootloader but when i flash with odin its show error i write full dump Samsung i9020/Nexus_S_i9020_Rom1.rar this one after dump phone samsung logo and not flash with odin i need i9020t full dump if any one have plz share thnx |
05-29-2012, 10:04 | #125 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | GT-i9023_Rev0.4 after resurrection detected as mass storage !!!! i've try resurrection with and without recovery and gremlin zone but phone still be detected as usb storage drivers all are ok & tested on fresh windows and installed SAMSUNG_USB_Driver_for_Mobile_Phones_v1_3_2300_0 i full erased device but still same i made a search but only found Nexus_S_i9020_Rom1_ok.bin Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9023 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9023 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Settings Code: 0x04010B00000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK WARNING: Erasing Error (0x24) at 0x000016800000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x000016F00000 is Ignored. Erase continues. Completed in 00:00:10.360 (Average Transfer Rate: 50606.95 kB/s) Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung I9023 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Settings Code: 0x04010B00000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Reading FLASH1 address space from 0x000000040000 to 0x000000040FFF Completed in 00:00:00.015 (Average Transfer Rate: 139810133.27 kB/s) Reading FLASH1 address space from 0x000000080000 to 0x000000080FFF Completed in 00:00:00.015 (Average Transfer Rate: 6.51 kB/s) Reading FLASH1 address space from 0x0000000C0000 to 0x0000000C0FFF Completed in 00:00:00.015 (Average Transfer Rate: 6.51 kB/s) ERROR: Couldn't find partition table location in the device memory. Code: Device Descriptor: bcdUSB: 0x0200 bDeviceClass: 0x00 bDeviceSubClass: 0x00 bDeviceProtocol: 0x00 bMaxPacketSize0: 0x40 (64) idVendor: 0x18D1 idProduct: 0x4E21 bcdDevice: 0x0227 iManufacturer: 0x01 0x0409: "Samsung" iProduct: 0x02 0x0409: "Nexus S" iSerialNumber: 0x03 0x0409: "3333EF14123E00EC" bNumConfigurations: 0x01 ConnectionStatus: DeviceConnected Current Config Value: 0x01 Device Bus Speed: Full Device Address: 0x04 Open Pipes: 2 Endpoint Descriptor: bEndpointAddress: 0x85 IN Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 Endpoint Descriptor: bEndpointAddress: 0x04 OUT Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 Configuration Descriptor: wTotalLength: 0x0020 bNumInterfaces: 0x01 bConfigurationValue: 0x01 iConfiguration: 0x00 bmAttributes: 0xC0 (Bus Powered Self Powered ) MaxPower: 0xFA (500 Ma) Interface Descriptor: bInterfaceNumber: 0x00 bAlternateSetting: 0x00 bNumEndpoints: 0x02 bInterfaceClass: 0x08 bInterfaceSubClass: 0x06 bInterfaceProtocol: 0x50 iInterface: 0x07 0x0409: "Mass Storage" Endpoint Descriptor: bEndpointAddress: 0x85 IN Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 Endpoint Descriptor: bEndpointAddress: 0x04 OUT Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 |
07-14-2012, 22:03 | #131 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Yes.it's old topic... ------------------ Both Phone Have a Same Pinout... Use I9023.dll...Press "Interface Pinout".....You Can See Pinout | |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
07-16-2012, 13:46 | #132 (permalink) |
Insane Poster Join Date: Dec 2011
Member: 1702235 Status: Offline Thanks Meter: 5 | That's awesome! I have this box only for 5days... Already fixed 2 phones, didn't realized that it has all pinouts i was checking in google before... Thanks a lot mate. I already love this box! |
07-29-2012, 03:06 | #133 (permalink) |
Insane Poster Join Date: Feb 2007 Location: Nhất Vũ - An Giang
Member: 443642 Status: Offline Sonork: 100.1619283 Thanks Meter: 7 | i9023 hang logo+ unlock bootlodaer die by RIFF hi, pls help me, i have phone I9023 hang logo and brick bootloder, i repairt boot ok by RIFF but after repairt LCD banlk, phone connect to PC ok but i can't uprom . Last edited by dcsmobile; 07-29-2012 at 03:12. |
07-29-2012, 10:25 | #134 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You Mean Phone Turn on Before Resurrect..? if Yes,,Please Replace eMMC Chip ----- I have few phone for 2 weeks ago....all phone come back to live after change eMMC(except one phone-i9023)...... ------------------------------- You Don't Need Repair Boot Area With Riff-Box if Phone Can Turn On(But Hang on logo) .... --------------------- For More Info Please Contact Me Via Sonork |
07-29-2012, 10:32 | #135 (permalink) |
Member: 443642 Status: Offline Sonork: 100.1619283 Thanks Meter: 7 | before repairt boot with RIFF JTAG, power on phone hang logo Google , volume up + volume down + power + insert cable usb ------>display Unlock Bootlodaer---->uprom eror, but phone connect to computer ok. |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
