02-04-2014, 20:04 | #1 (permalink) |
Insane Poster Join Date: Dec 2006
Member: 411511 Status: Offline Thanks Meter: 1 | i9070 can't repaire Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x59): Communication is not established. Terminating. 2- Connecting to the dead body...OK Detected dead body ID: 0x000000FF - WRONG!!! ERROR: Current ID does not belong to the Samsung I9070 family. where's the problem did any one have a solution???? |
02-04-2014, 20:43 | #2 (permalink) | |
Insane Poster Join Date: Aug 2012
Member: 1802331 Status: Offline Thanks Meter: 13 | Quote:
02-04-2014, 23:37 | #5 (permalink) | ||
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | [QUOTE] Quote:
You Have Bad Connection,I See in your log "0X000000FF - WRONG" This ID is not Real ID...So Just Check Your Connection | ||
02-05-2014, 14:10 | #6 (permalink) |
Member: 411511 Status: Offline Thanks Meter: 1 | mr/ babak i'm tried to change the soldering three times and every one has the same problem i don't think that is any problem in the connection with the box but when i press resurrection without battery the phone goes to connected and when i but the battery he give me that error . and i'm tried to Resurrect the phone with another box and another pc alsothe same error |
02-06-2014, 01:23 | #8 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Follow This 1-solder wires 2-connect pcb to usb flat cable 3-connect usb to phone and pc 4-Press Resurrect and *** Quickly insert battrey Or Power Supply *** Please don't forget install U8500 USBROM driver from RIFF Installed directory | |
02-13-2014, 00:57 | #9 (permalink) |
Member: 411511 Status: Offline Thanks Meter: 1 | i did as what you say and this is the result: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I9070 V1.0.4762.51152] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! WARNING: Embedded I/O Voltage is overriden to 3.00V Set I/O Voltage reads as 2.99V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x59): Communication is not established. Terminating. |
