09-13-2011, 13:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | i9100 dead boot repair done Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [Samsung i9100] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.78V, TCK Frequency is 10 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (0x03AB400000 Bytes) Flashing the dead body...OK Resurrection complete! best regards |
The Following 7 Users Say Thank You to c_ahmad79 For This Useful Post: |
09-14-2011, 03:33 | #3 (permalink) |
Freak Poster Join Date: Feb 2004 Location: BY Age: 49
Member: 52495 Status: Offline Thanks Meter: 25 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [Samsung i9100] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (0x03AB400000 Bytes) Flashing the dead body...OK Resurrection complete! But no download mode With "Initiate Download mode" Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [Samsung i9100] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Initializing internal hardware configuration...OK Uploading selected SPL code into RAM...OK Executing the uploaded SPL code...OK In about six seconds phone shall be enumerated by PC No download mode |
09-16-2011, 00:09 | #5 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1501506 Status: Offline Thanks Meter: 47 | I'm currently having the same problem. When I try to use the "Initiate Download Mode" option and hold the button combo, it fails. I'm guess the IBL is toast but I was hoping that the initiate download mode feature won't work for me. Any advice RIFF team? Legija WHERE HAVE YOU BEEN! Been missing you on ICQ buddy! Btw I've repaired over 5 i9100's and this is not a user or soldering problem. |
04-17-2012, 04:36 | #7 (permalink) |
Junior Member Join Date: Mar 2009 Location: CHINA
Member: 1000329 Status: Offline Thanks Meter: 2 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.42 Selected Resurrector: [Samsung i9100 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000000 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. i had resurrection once time but it gone to recovery mode when i hold vol- home and power key. Then it could not show anything like dead again.But can not resurrection anymore and always currupt with error . Anyone help me ? |
04-17-2012, 18:41 | #8 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi kucky520 (This is very Old Thread ....Please Open your Topic for own problem) Anyway: it's mean damaged flash chip because DCC Loader can not detected it... Quote:
01-05-2013, 22:10 | #10 (permalink) |
Freak Poster Join Date: May 2012
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Ma Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9100 V1.0.4724.60074] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - IGNORED! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
01-06-2013, 02:26 | #11 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
This is clear case if damaged eMMC... So,You need replace by new one | |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
Contact Service Repairer 1.2 by Bartek | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-23-2011 09:00 |
Phone not respond! (Load boot data) Need a help ! | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-23-2001 02:10 |
New!! Nokia Flash Checksum And Contact Service Repair | HookerGsM | Main Sales Section | 0 | 01-02-2001 10:12 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
