01-13-2014, 21:58 | #1 (permalink) |
Freak Poster Join Date: May 2001
Member: 4527 Status: Offline Thanks Meter: 40 | I9100 ERROR(0x49) when resurrecting Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I9100 V1.0.4850.415] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x49): Communication is not established. Terminating. regards |
01-15-2014, 17:15 | #3 (permalink) |
Member: 4527 Status: Offline Thanks Meter: 40 | There some more details regarding this phone. Sometimes I get another error: "ERROR: Read/Write memory failed during H/W Init." ...and power switch must always be pressed on when connecting (even when I'm using usb cable and battery in) |
01-16-2014, 02:07 | #4 (permalink) |
Registered User Join Date: Sep 2006 Location: viet nam
Member: 350201 Status: Offline Thanks Meter: 52 | So, i have same problem, i think h/w not good although check connect good....You can try when box check Establish communication with the phone..connect again cable usb... |
