09-18-2012, 18:41 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | i9100 error i tried many times, same error, change the cable, same error, resolder 3 times, same error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung i9100 V1.0.4582.4854] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 6 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VIS00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VIS00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Stopped due to multiple communication errors. Terminating at 0x000000000000 |
09-18-2012, 19:31 | #2 (permalink) | |
No Life Poster Join Date: Feb 2012 Location: Romania Age: 41
Member: 1722871 Status: Offline Thanks Meter: 116 | Quote:
http://forum.gsmhosting.com/vbb/f634...ution-1508808/ | |
The Following User Says Thank You to ZiDanRO For This Useful Post: |
09-18-2012, 20:17 | #3 (permalink) |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | thanks now have another error Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. mersi, bafta |
09-18-2012, 23:11 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Read :RIFF JTAG Box FAQ - ERROR: Failed due to multiple communication errors. -------------- Please Check : 1-Check again all soldered wires 2-Connect Power Supply 3-Set speed at 6MHZ or 8MHZ 4-Press and Keep Power on Key....or...Connect USB Cable 5-Press Resurrect |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
09-19-2012, 13:49 | #5 (permalink) |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | thanks to everybody fixed with the link recommended http://forum.gsmhosting.com/vbb/f634...ution-1508808/ |
09-19-2012, 16:17 | #6 (permalink) | |
09-20-2012, 02:34 | #7 (permalink) | ||
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please post full log... or contact me via sonork --------- if you have this error at 0%...it's clear case of damaged eMMC Quote:
if you have error on 100% and this error: you need try method by posted link Quote:
09-20-2012, 05:16 | #8 (permalink) | |
Code: [19/9/2012 1:19:39 PM] Open serial port...OK [19/9/2012 1:19:39 PM] Connecting to the RIFF Box...OK [19/9/2012 1:19:39 PM] Firmware Version: 1.33, JTAG Manager Version: 1.44 [19/9/2012 1:19:39 PM] Selected Resurrector: [Samsung i9100 V1.0.4582.4854] [19/9/2012 1:19:39 PM] [19/9/2012 1:19:39 PM] Connecting to the dead body...OK [19/9/2012 1:19:39 PM] Detected dead body ID: 0x4BA00477 - CORRECT! [19/9/2012 1:19:39 PM] Set I/O Voltage reads as 2.81V, TCK Frequency is 4 MHz [19/9/2012 1:19:39 PM] [19/9/2012 1:19:39 PM] Resurrection sequence started. [19/9/2012 1:19:39 PM] Establish communication with the phone...OK [19/9/2012 1:19:39 PM] Initializing internal hardware configuration...OK [19/9/2012 1:19:39 PM] Uploading resurrector data into memory...OK [19/9/2012 1:19:39 PM] Starting communication with resurrector...OK [19/9/2012 1:19:39 PM] [19/9/2012 1:19:39 PM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) [19/9/2012 1:19:39 PM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) [19/9/2012 1:19:39 PM] [19/9/2012 1:19:39 PM] Flashing the dead body... [19/9/2012 1:19:39 PM] WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. [19/9/2012 1:19:39 PM] ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x010000) | |
02-12-2013, 11:24 | #9 (permalink) |
Freak Poster Join Date: May 2010 Location: INDIA
Member: 1302506 Status: Offline Sonork: india Thanks Meter: 14 | Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (0x0003AB400000 Bytes = 14.68 GB) Flashing the dead body...OK Resurrection complete! but not power on ple hailp |
05-06-2013, 09:14 | #10 (permalink) |
Junior Member Join Date: Apr 2013 Location: Saudi Arabia
Member: 1921649 Status: Offline Thanks Meter: 0 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9100 V1.0.4850.415] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.84V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. what solutions bro i am watting for your reply |
05-06-2013, 10:15 | #11 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Please Read : RIFF JTAG Box FAQ - ERROR: RAM memory selftest failed. | |
