Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 09-17-2012, 21:31   #1 (permalink)
gsmnilambur's Avatar
Member: 1577928
Sonork: 100.1611402
Thanks Meter: 37
Samsung i9100 resurrection faild
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.33, JTAG Manager Version: 1.44
Selected Resurrector: [Samsung i9100 V1.0.4582.4854]
Connecting to the dead body...OK
Detected dead body ID: 0x4BA00477 - CORRECT!
Set I/O Voltage reads as 2.81V, TCK Frequency is 10 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048
ERROR: Selected FLASH Chip was not initialized by the DCC Loader.
*******R DID WRONG FLASH AFTER MOBILE IS DEAD THAT WHAT HE SAID THEN I TRY TO DO DEAD BOOT ALL THE TIME I GOT SAME ERROR
AND WHEN I CONNECT USB DETECT PCA AND ITS ASK FOR DRIVER SEC S5PC110 Test B/D NOT ENTER DOWNLOAD MODE
THEN I TRY TO SEARCH RIFF JTAG Box FAQ - powered by phpMyFAQ 2.7.5 HEAR I FOUND HARDWARE PROBLEM AFTER I RE HOT SD CHIP SAME STILL SAME ERROR
SIR PLS GIVE ME ONE GOOD ANSWER ITS HARDWARE OR SOFTWARE AND HOW TO SOLVE
THANK YOU
Old 09-18-2012, 07:44   #2 (permalink)
islamic.tj's Avatar
Member: 1533366
Thanks Meter: 131
change TCK Frequency is 8 MHz
Old 09-18-2012, 08:10   #3 (permalink)
Member: 1577928
Sonork: 100.1611402
Thanks Meter: 37
bro i try all TCK frequency same error coming!!!!!!
hear is Resurrection DOWNLOAD MOD
Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz
Uploading selected SPL code into RAM...OK
Executing the uploaded SPL code...FAILED
ERROR: DCC Loader Execute failed. Terminating.
THANK YOU
Old 09-18-2012, 09:35   #4 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
You need replace eMMC Chip..
Why do you think phone can repair by heating?
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 10-07-2012, 19:40   #5 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
pls see me emmc chip
Old 10-07-2012, 22:19   #6 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Sorry,i don't have any photo for now
But You can find eMMC chip in Your PCB ... Just Look Behind the Mainbord ,It's """ Samsung KMVL000M"
Old 11-09-2012, 15:22   #7 (permalink)
Member: 17621
Thanks Meter: 23
I9100 dead,
Hi,
when i try to initiate download mode i9100 i got this error , what may be the prob?
Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz
And when i try to resurrect the i9100,
Firmware Version: 1.34, JTAG Manager Version: 1.45
kumar.
Old 11-09-2012, 22:03   #8 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
This is bad eMMC :
You Need replace new one
RIFF JTAG Box FAQ - WARNING: DCC Loader was unable to initialize FLASH1 chip.
Old 11-22-2012, 10:11   #9 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
Firmware Version: 1.34, JTAG Manager Version: 1.47
I9100
Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz
Old 11-22-2012, 13:13   #10 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
This is clear case of damaged eMMC Chip
So,Make Sure About Soldered Wires
Then,You Need Replace eMMC Chip
Old 11-23-2012, 12:17   #11 (permalink)
Member: 1558861
Sonork: aftabmiraj15
Thanks Meter: 4
Old 11-23-2012, 12:38   #12 (permalink)
Member: 1558861
Thanks Meter: 4
Old 12-26-2012, 12:30   #13 (permalink)
Member: 263548
Thanks Meter: 24
Help Ressurrection samsung i9100 error
hi i have problem to ressuction my samsung i91000
Firmware Version: 1.34, JTAG Manager Version: 1.48
Selected Resurrector: [Samsung I9100 V1.0.4724.60074]
No Resurrection Data is available for the eMMC Chip with Capacity = 0B
WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB
Any ideal all supporter
thanks..
Old 12-26-2012, 12:40   #14 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
There is no flash chip (eMMC) detected. Obviously You have to check it, either reball it or replace with new one.
The Following User Says Thank You to legija For This Useful Post:
Old 01-03-2013, 09:36   #15 (permalink)
Member: 474934
Sonork: 100.1619723
Thanks Meter: 12
i9100 0x00000048
WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14,68GB
Page generated in 0.24724 seconds with 9 queries
