10-24-2011, 18:56 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 50
Member: 256461 Status: Offline Sonork: 100.1608049 Thanks Meter: 90 | unable to initialize FLASH1 chip. Error code: 0x00000000 10/24/2011 8:51:01 PM] Open serial port...OK [10/24/2011 8:51:01 PM] Connecting to the RIFF Box...OK [10/24/2011 8:51:01 PM] Firmware Version: 1.27, JTAG Manager Version: 1.36 [10/24/2011 8:51:01 PM] Selected Resurrector: [Samsung i9100] [10/24/2011 8:51:01 PM] [10/24/2011 8:51:01 PM] Connecting to the dead body...OK [10/24/2011 8:51:01 PM] Detected dead body ID: 0x4BA00477 - IGNORED! [10/24/2011 8:51:01 PM] Set I/O Voltage reads as 2.82V, TCK Frequency is 8 MHz [10/24/2011 8:51:01 PM] [10/24/2011 8:51:01 PM] Resurrection sequence started. [10/24/2011 8:51:01 PM] Establish communication with the phone...OK [10/24/2011 8:51:01 PM] Initializing internal hardware configuration...OK [10/24/2011 8:51:01 PM] Uploading resurrector data into memory...OK [10/24/2011 8:51:01 PM] Starting communication with resurrector...OK [10/24/2011 8:51:01 PM] [10/24/2011 8:51:01 PM] WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000000 [10/24/2011 8:51:01 PM] [10/24/2011 8:51:01 PM] ERROR: Selected FLASH Chip was not initialized by the DCC Loader. [10/24/2011 8:51:01 PM] [FINISH OPERATION_ID = RESURRECT] |
02-12-2012, 09:31 | #2 (permalink) |
Member: 256461 Status: Offline Sonork: 100.1608049 Thanks Meter: 90 | error:no response from the riff box Trying to resurrect galaxy s2 I9100 but iam getting the following error,double checked solders and chkd jtag chain jtag chain: 2/11/2012 6:44:53 PM] [START OPERATION_ID = RESTART_TARGET] [2/11/2012 6:44:53 PM] Open serial port...OK [2/11/2012 6:44:53 PM] Connecting to the RIFF Box...OK [2/11/2012 6:44:53 PM] Firmware Version: 1.30, JTAG Manager Version: 1.38 [2/11/2012 6:44:53 PM] Selected Resurrector: [Samsung i9100] [2/11/2012 6:44:53 PM] [2/11/2012 6:44:53 PM] Restarting target (nRST Low then High)...OK [2/11/2012 6:44:53 PM] [FINISH OPERATION_ID = RESTART_TARGET] resurrection: [2/11/2012 6:45:04 PM] [START OPERATION_ID = RESURRECT] [2/11/2012 6:45:13 PM] Open serial port...OK [2/11/2012 6:45:13 PM] Connecting to the RIFF Box...OK [2/11/2012 6:45:13 PM] Firmware Version: 1.30, JTAG Manager Version: 1.38 [2/11/2012 6:45:13 PM] Selected Resurrector: [Samsung i9100] [2/11/2012 6:45:13 PM] [2/11/2012 6:45:13 PM] Connecting to the dead body...OK [2/11/2012 6:45:13 PM] Detected dead body ID: 0x4BA00477 - CORRECT! [2/11/2012 6:45:13 PM] Set I/O Voltage reads as 2.82V, TCK Frequency is 8 MHz [2/11/2012 6:45:13 PM] [2/11/2012 6:45:13 PM] Resurrection sequence started. [2/11/2012 6:45:13 PM] Establish communication with the phone...OK [2/11/2012 6:45:13 PM] Initializing internal hardware configuration...OK [2/11/2012 6:45:13 PM] Uploading resurrector data into memory...OK [2/11/2012 6:45:13 PM] Starting communication with resurrector...FAILED [2/11/2012 6:45:13 PM] ERROR: No response from the RIFF Box. [2/11/2012 6:45:13 PM] [FINISH OPERATION_ID = RESURRECT] what may be the problem,is this problem with hardware or riff box or connections,just before this fone i have sucessfully done one htc hd7.masters pls look into it. sajidmirza. |
02-12-2012, 21:01 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | i think better not use HALT,in jtag chain page but try this: check all wire speed 6mhz don't use usb input battery and hold power on key press "resurect" and also stile hold power on key |
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post: |
04-24-2012, 11:33 | #4 (permalink) |
Member: 256461 Status: Offline Sonork: 100.1608049 Thanks Meter: 90 | Can't delete files and flash I9100 I9100 its working but cant delete/remove from sd card,made full wipe from recovery,flashed in odin with full firmware and pit file,after flashing there is still old firmware in it.previous firmware is JPKJ2 stock. i tried with different firmwares successfully but can't remove the old firmware.Does writing with full dump helps me.pls advice.Even cant remove the known user lock. sajidmirza |
04-24-2012, 12:48 | #6 (permalink) |
Member: 256461 Status: Offline Sonork: 100.1608049 Thanks Meter: 90 | [QUOTE=BABAK NURI;8349183]Hi It's Mean a eMMC Fault. So,full dump not work,also not good idea Please tell me about phone history[/QUOTE No physical damage,no waterlog customer wants to delete some photos and can't delete,not rooted,stock firmware installed and some applications like viber and whatsapp,azaan etc,. and with password offcourse.internal sd is visible and able to connect and view in pc. sajidmirza |
04-25-2012, 08:34 | #7 (permalink) |
Freak Poster Join Date: Dec 2009 Location: in my home Age: 39
Member: 1184653 Status: Offline Sonork: 100.1615484 Thanks Meter: 64 | Samsung i9100 Resurrection ERROR Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung i9100 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VIS00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VIS00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Stopped due to multiple communication errors. Terminating at 0x000000000000 |
04-25-2012, 18:41 | #12 (permalink) | |
Junior Member Join Date: Apr 2011
Member: 1555702 Status: Offline Thanks Meter: 1 | Hi, same to me progress bar stopps at 100% and Quote:
Any ideas how to fix it. | |
04-26-2012, 00:59 | #15 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi What's a phone history??? If phone brickd by wrong firmware ,usually repaired done by jtag If the phone is broken spontaneously,or physical broken or water damage,you can't repair this by jag box |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
