12-13-2012, 15:21 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 41
Member: 114705 Status: Offline Thanks Meter: 22 | i9100 help me I9100 resurrection ok, but no download mode. Vol dwn+home+power not working and usb jig not working Please help me. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9100 V1.0.4724.60074] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14,68GB Flashing the dead body...OK Resurrection complete! |
12-13-2012, 16:15 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | It can be due to two problems: 1. Battery is empty 2. Phone has some HW problem (which can be many many many problems ) |
The Following User Says Thank You to legija For This Useful Post: |
12-26-2012, 12:47 | #6 (permalink) | |
Freak Poster Join Date: Apr 2006
Member: 263548 Status: Offline Thanks Meter: 24 | Quote:
Test by me work 100% | |
12-28-2012, 22:38 | #10 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I9100G based on Omap4430 and You Can't Resurrect with normal I9100.dll So,Your Phone not is "G" Model -- For find exactly model,You need look PCB For Golden Printed Model ---- Any way,if phone is i9100 and not start after Resurrect,You need replace eMMC,Becuase eMMC is bootable |
