Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > RIFFBOX
Old 08-02-2012, 14:50   #1 (permalink)
Member: 13569
Sonork: 1619596
i9100 resurrection ok - download mode ok - odin write fail
Hi Mates!
I hav an i9100 Resurrected with riff everithying goes ok but after start flash with odin every firmware stops at writing FSIMAGE. are there any hint to do with RIFF or this is HW fault? /odin stopps allways the same place/
Many thanx for answer.
dazexy
Old 08-02-2012, 15:47   #2 (permalink)
R.Nasir.Ali's Avatar
Member: 1141761
Sonork: 100.1618159
Arrow Hello!
search your proper file and follow the instruction to load from here SAMSUNG
thank u
nasir
Old 08-03-2012, 11:43   #3 (permalink)
Member: 13569
Sonork: 1619596
Hi mates!
sorry, but "proper" file dosn't help on me. :-) I think there is somting with new resurrector dll, because i see allmost the same problem with other person. Or there are a strange same situation at the same time at two different user.
and pls... I know how to use odin, and try many files and every fw write stop at the same place.
So 2 option remains: 1. HW problem, or resurector not works properly on every i9100.
Pls supporters give me some hint what to try out.
many thanx.
dazexy
Old 08-03-2012, 12:18   #4 (permalink)
Member: 5926
Originally Posted by dazexy View Post
Hi Mates!
dazexy
why dont you write FULL image with riffbox?
Old 08-03-2012, 13:19   #5 (permalink)
Member: 1372118
try flash with full pack
include boot, PDA, Modem N CSC
Old 08-03-2012, 13:29   #6 (permalink)
Member: 1372118
Old 08-03-2012, 14:19   #7 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Sir Try Flash With SPT Box i was stuck in tjis Problem and i fix it SPT Box
Old 08-03-2012, 15:11   #8 (permalink)
armanhosting's Avatar
Member: 410890
emmc damage thats why even flash with different flashfile still fail
Old 08-03-2012, 15:18   #9 (permalink)
Member: 566133
use pit file , tick repartion when flash .
Old 08-03-2012, 15:28   #10 (permalink)
Member: 13569
Sonork: 1619596
a tought that, but its a bit slow ~ 20 hours and nobody wants to upload such a big file ~ 16 GB
anyway seems worthfull idea...
Old 08-03-2012, 15:31   #11 (permalink)
Member: 13569
Sonork: 1619596
thanx for a tip will try
can you write me the firmware version witch was sucess in your case?
Thanx
Old 08-03-2012, 16:42   #12 (permalink)
Member: 1703991
from where can i get i9100 full pack flash files ???? any link please
Old 08-03-2012, 19:30   #13 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Hi
I have full 16GB dump file but this is useless...
You Have 2 option:
First,Maybe Possible,You did select flash lock in odin...
Second: eMMC have a Bad Block And Usually you need replace
But
You Have 2 Option:
Please Note:*** Both Method Not Tested By Me And You Have Own Choice And Own RISK ***
1-You can Write BOOT.bin (Need Extract Your Firmware and Use Boot.bin)
Then Write Boot.bin on ROM2
use This Topic for Guide:
http://forum.gsmhosting.com/vbb/f634...ution-1508808/
2-Use Patched Pit....Make By XDA Guys
You Can Use Pathed Pit and select Firmware(3 or 4 Parts)...Check "Repartition"..Then Click "Start"
Here is the pathed Pit:
PIT file method to revive your phone from a MMC_CAP_ERASE brick - xda-developers
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 08-13-2012, 21:39   #14 (permalink)
Member: 13569
Sonork: 1619596
Originally Posted by BABAK NURI View Post
Hi
You Have 2 option:
But
You Have 2 Option:
thanx for help...
i previously contacted with you via sonork and u give me a special file, but my problem is not solved allready. I have the problem with FACTORYFS.img writing not DATA.img. So i read your last post and tried all the patched pits posted on X D A forums but allways odin stops at FACTORYFS.img so this means that my EMMC is full of bugs? And i noticed that it dos not mather witch PIT file i use ODIN stops always the same place. Is it possible that odin overrides the offset mapped in patched pit?
Many thax for answer.
dazexy
Old 08-13-2012, 21:48   #15 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
thanx for help...
dazexy
Hi
Please Contact me via sonork again
Please sold all pinout,Then contact me...
I need check something via remote
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 09-16-2011 13:43
download Datasuite 3.0 zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 10-31-1999 01:35
Upload / Download eeprom program for 51xx/61xx Ryu Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-07-1999 14:03
Page generated in 0.37450 seconds with 11 queries
