04-02-2013, 06:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 711273 Status: Offline Thanks Meter: 81 | i9100 WARNING: Programming Error (0x25) at 0x00000003C000 is handled as Cut Excess. e Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9100 V1.0.4724.60074] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (000000, 0x000200000000 Bytes = 8.00 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (000000, 0x000000100000 Bytes = 1.00 MB) No Resurrection Data is available for the eMMC Chip with Capacity = 8.00GB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000004000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000008000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000000C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000010000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000014000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000018000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000001C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000020000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000024000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000028000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000002C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000030000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000034000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000038000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000003C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001800000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001804000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001808000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000180C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001810000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001814000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001818000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000181C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001820000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001824000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001828000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000182C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001830000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001834000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001838000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000183C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001840000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001844000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001848000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000184C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001850000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001854000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001858000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000185C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001860000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001864000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001868000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000186C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001870000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001874000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001878000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000187C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001880000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001884000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001888000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000188C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001890000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001894000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001898000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000189C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018A0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018A4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018A8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018AC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018B0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018B4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018B8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018BC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018C0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018C4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018C8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018CC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018D0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018D4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018D8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018DC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018E0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018E4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018E8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018EC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018F0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018F4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018F8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000018FC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001900000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001904000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001908000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000190C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001910000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001914000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001918000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000191C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001920000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001924000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001928000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000192C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001930000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001934000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001938000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000193C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A04000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A08000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A0C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A14000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A18000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A1C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A24000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A28000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A2C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A30000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A34000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A38000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A3C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A40000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A44000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A48000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A4C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A50000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A54000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A58000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A5C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A60000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A64000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A68000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A6C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A70000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A74000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A78000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A7C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A80000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A84000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A88000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A8C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A90000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A94000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A98000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001A9C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AA0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AA4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AA8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AAC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AB0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AB4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AB8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001ABC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AC0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AC4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AC8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001ACC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AD0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AD4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AD8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001ADC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AE0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AE4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AE8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AEC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AF0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AF4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AF8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001AFC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B04000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B08000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B0C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B14000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B18000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B1C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B24000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B28000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B2C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B30000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B34000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B38000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001B3C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C00000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C04000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C08000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C0C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C10000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C14000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C18000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C1C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C20000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C24000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C28000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C2C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C30000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C34000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C38000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C3C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C40000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C44000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C48000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C4C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C50000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C54000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C58000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C5C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C60000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C64000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C68000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C6C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C70000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C74000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C78000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C7C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C80000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C84000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C88000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C8C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C90000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C94000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C98000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001C9C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CA0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CA4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CA8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CAC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CB0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CB4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CB8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000001CBC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023C0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023C4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023C8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023CC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023D0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023D4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023D8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023DC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023E0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023E4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023E8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023EC000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023F0000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023F4000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023F8000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x0000023FC000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3A (0x000000). Trying to recover...OK WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000004000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000008000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000000C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000010000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000014000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000018000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000001C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000020000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000024000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000028000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000002C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000030000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000034000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000038000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000003C000 is handled as Cut Excess. Resurrection complete! how to solve riff team |
