12-27-2012, 15:30 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: freak land Age: 44
Member: 8866 Status: Offline Thanks Meter: 50 | i9100g after ressurection won't enter download mode i have a i9100g wich died during root after resurrection when i put the batter in it, only shows a battery on screen without me touching the power button if i press the power button for about 15 seconds it hangs in standard power up logo and that's pretty much it. this is the log and some pics : Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (0x0003AB400000 Bytes = 14.68 GB) Flashing the dead body...OK Resurrection complete! |
12-27-2012, 15:42 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Saudi Arabia
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | Quote:
your phone is water damaged from charging portion. open it and check. best regards. | |
The Following User Says Thank You to tayyab007 For This Useful Post: |
12-27-2012, 23:36 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Try replace flat charging or if you want dl-mode try : disconnect flat charging from pcb remove battrey for 30sec and put back hold vol_Down and Home connect flat charging **you have dl-mode after few sec no need press power on key because your damaged flat can work like power key |
02-12-2013, 11:29 | #5 (permalink) |
Freak Poster Join Date: May 2010 Location: INDIA
Member: 1302506 Status: Offline Sonork: india Thanks Meter: 14 | Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (0x0003AB400000 Bytes = 14.68 GB) Flashing the dead body...OK Resurrection complete! but not power on ple hailp |
