07-08-2013, 10:04 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: iran.ahwaz Age: 41
Member: 133927 Status: Offline Thanks Meter: 20 | i9100g boot repair please help me Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (0x0003AB400000 Bytes = 14.68 GB) Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x27 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000001800000 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the dead body...OK Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Detected dead body ID: 0x3BA00477 please help me how to repair this phone? tanks |
07-08-2013, 16:05 | #3 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | Check all your wire connections first, Make sure phone is powered on...try with power supply/USB Cord ...or only Power supply and then push power button on the phone. Try setting the TCK speed at 2 or 4 Mhz |
The Following User Says Thank You to spagman For This Useful Post: |
07-08-2013, 17:32 | #4 (permalink) |
Member: 133927 Status: Offline Thanks Meter: 20 | i cheak all opthion but not working. i think dll is problam i download new dll today. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (0x0003AB400000 Bytes = 14.68 GB) Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x27 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000001800000 |
07-09-2013, 01:00 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Why Not Repair Bricked Phone By "Omap-Flasher" Via USB...? http://forum.gsmhosting.com/vbb/f634...i9300-1465412/ |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
07-09-2013, 09:45 | #7 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Yes,Of Course ...Many Device Have eMMC Problem...if Mr.Legija Told You For Replace,for sure you need replace But Did You Check With Omap-Flasher??? if no,plz contact me via sonork Thanks |
