06-16-2012, 15:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | I9100g Resurrection complete! but still Dead Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (0x0003AB400000 Bytes = 14.68 GB) Flashing the dead body...OK Resurrection complete! ,what need do Next ? |
06-16-2012, 16:38 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,308 | what about this method can you try with this method :http://forum.gsmhosting.com/vbb/f634...eeeee-1465412/ |
06-16-2012, 17:38 | #3 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Repair Process Complete .Phone Restart on Download mode and Stucked There , No Driver ask and nothing in Device manager |
07-01-2012, 16:18 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Saudi Arabia
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the target...OK Set I/O Voltage reads as 2.60V, TCK Frequency is 8 MHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x3BA00477, IR Length = 0x04 bits Device on TAP #1: ID = 0xFFFFFFFE, IR Length = 0x06 bits Total IR length: 0x000A bits what is the problem? any body help me out. thanks & regards. |
07-01-2012, 16:22 | #6 (permalink) |
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000034 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. same phone if try to recover through riff that error comes. best regards. |
07-01-2012, 18:02 | #7 (permalink) |
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [Samsung i9100G XLoader+ V1.00] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 18 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (0x0003AB400000 Bytes = 14.68 GB) Flashing the dead body...OK Resurrection complete! |
FBUS works but MBUS not! PLS Help! | Upo | Nokia Hardware & Hardware Repair | 5 | 09-12-2000 14:54 |
6110 unlocked but wont give reception | KingOfKingston | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-10-2000 22:15 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
Still with nokia 5110 ver 5.24 | VirtualM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-11-1999 18:57 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
