01-05-2013, 17:06 | #1 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 393902 Status: Offline Thanks Meter: 4 | i9100P bricked after upgrade After this phone was dead and didn't go into download mode (by pressing button or jig plug). I tried to resurrect by RIFF and then download mode started. When I flashed onefilepackage to 4.0.3 or 4.3.6 it was successfull but it got stuck on logo. When I flashed 3filespackage to 4.0.3 then it stuck on data fs. Today I tried a few times to ressurect this phone one more time. Last time was successful. When I connect a jig plug then phone shows green android logo (DM). What should I do now? (which version of software 2.3.6, 4.0.3, 4.3.6, one or three files package, which PIT file) Is it possible that the eMMc part is broken and needs to be replaced? [2013-01-05 14:28:08] [START OPERATION_ID = RESURRECT] [2013-01-05 14:28:23] Open serial port...OK [2013-01-05 14:28:23] Connecting to the RIFF Box...OK [2013-01-05 14:28:23] Firmware Version: 1.34, JTAG Manager Version: 1.48 [2013-01-05 14:28:23] Selected Resurrector: [Samsung I9100 V1.0.4724.60074] [2013-01-05 14:28:23] [2013-01-05 14:28:23] Connecting to the dead body...OK [2013-01-05 14:28:23] Detected dead body ID: 0x4BA00477 - CORRECT! [2013-01-05 14:28:23] Set I/O Voltage reads as 2.81V, TCK Frequency is 100 kHz [2013-01-05 14:28:23] [2013-01-05 14:28:23] Resurrection sequence started. [2013-01-05 14:28:23] Establish communication with the phone...OK [2013-01-05 14:28:23] Initializing internal hardware configuration...OK [2013-01-05 14:28:23] Uploading resurrector data into memory...OK [2013-01-05 14:28:23] Starting communication with resurrector...OK [2013-01-05 14:28:23] [2013-01-05 14:28:23] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) [2013-01-05 14:28:23] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) [2013-01-05 14:28:23] [2013-01-05 14:28:23] Selected Resurrection Data for the eMMC Chip with Capacity = 14,68GB [2013-01-05 14:28:23] [2013-01-05 14:28:23] Flashing the dead body... [2013-01-05 14:28:23] ERROR: Failed due to multiple communication errors. Terminating at 0x000000000000 [2013-01-05 14:28:23] [FINISH OPERATION_ID = RESURRECT] [2013-01-05 14:28:29] [START OPERATION_ID = RESURRECT] [2013-01-05 14:28:37] Open serial port...OK [2013-01-05 14:28:37] Connecting to the RIFF Box...OK [2013-01-05 14:28:37] Firmware Version: 1.34, JTAG Manager Version: 1.48 [2013-01-05 14:28:37] Selected Resurrector: [Samsung I9100 V1.0.4724.60074] [2013-01-05 14:28:37] [2013-01-05 14:28:37] Connecting to the dead body...OK [2013-01-05 14:28:37] Detected dead body ID: 0x4BA00477 - CORRECT! [2013-01-05 14:28:37] Set I/O Voltage reads as 2.81V, TCK Frequency is 100 kHz [2013-01-05 14:28:37] [2013-01-05 14:28:37] Resurrection sequence started. [2013-01-05 14:28:37] Establish communication with the phone...FAILED [2013-01-05 14:28:37] ERROR(0x59): Communication is not established. Terminating. [2013-01-05 14:28:37] [FINISH OPERATION_ID = RESURRECT] [2013-01-05 14:28:54] [START OPERATION_ID = RESURRECT] [2013-01-05 14:30:30] Open serial port...OK [2013-01-05 14:30:30] Connecting to the RIFF Box...OK [2013-01-05 14:30:30] Firmware Version: 1.34, JTAG Manager Version: 1.48 [2013-01-05 14:30:30] Selected Resurrector: [Samsung I9100 V1.0.4724.60074] [2013-01-05 14:30:30] [2013-01-05 14:30:30] Connecting to the dead body...OK [2013-01-05 14:30:30] Detected dead body ID: 0x4BA00477 - CORRECT! [2013-01-05 14:30:30] Set I/O Voltage reads as 2.81V, TCK Frequency is 9 MHz [2013-01-05 14:30:30] [2013-01-05 14:30:30] Resurrection sequence started. [2013-01-05 14:30:30] Establish communication with the phone...OK [2013-01-05 14:30:30] Initializing internal hardware configuration...OK [2013-01-05 14:30:30] Uploading resurrector data into memory...OK [2013-01-05 14:30:30] Starting communication with resurrector...OK [2013-01-05 14:30:30] [2013-01-05 14:30:30] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) [2013-01-05 14:30:30] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) [2013-01-05 14:30:30] [2013-01-05 14:30:30] Selected Resurrection Data for the eMMC Chip with Capacity = 14,68GB [2013-01-05 14:30:30] [2013-01-05 14:30:30] Flashing the dead body...OK [2013-01-05 14:30:30] Resurrection complete! [2013-01-05 14:30:30] [FINISH OPERATION_ID = RESURRECT] |
01-06-2013, 02:35 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Just Try with attached .pit file with 3-4 parts firmware(2.3.4 or 4.0.3) and post result here... For First Try with I9100stnd.pit....if not work try with I9100-.pit...next is I9100fs.pit and last is I9100ums.pit... Thanks |
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post: |
