09-18-2012, 21:03 | #1 (permalink) |
Insane Poster Join Date: Feb 2012 Location: Portugal, Funchal
Member: 1720469 Status: Offline Thanks Meter: 12 | I9100T is possible to repair with the I9100 DLL??? Regards |
09-19-2012, 10:50 | #3 (permalink) |
Member: 1720469 Status: Offline Thanks Meter: 12 | Yes... that is my worry... :-( So the short answer is that for the moment there is no direct support for I9100T, correct? I'll try to look for alternatives... Thank you very much for your reply Babak. |
02-25-2014, 15:58 | #5 (permalink) |
Registered User Join Date: Jun 2005 Location: jamnagar gujarat india
Member: 149938 Status: Offline Thanks Meter: 47 | i9100t problem. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I9100 V1.0.4850.415] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! still not d/w mode. |
