12-21-2013, 14:10 | #1 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | i9205 repair problem I'm having a problem with reserructing I9205...here is the log: Code: Selected Resurrector: [Samsung I9205 V1.0.4969.6324] Connecting to the dead body...OK Detected dead body ID: 0x308930E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. b.r. |
04-15-2015, 11:46 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | some problem Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I9205 V1.0.5113.60621] Connecting to the dead body...OK Detected dead body ID: 0x308930E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 1 MHz Settings Code: 0x00010600000000000000000020000001 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
