05-06-2013, 21:59 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi WoW...This Very Soon Time For Bricked Galaxy S4.... So,What Happen For Your Phone...? |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
05-31-2013, 11:52 | #6 (permalink) |
Freak Poster Join Date: Dec 2009 Location: UK. Worcester Age: 35
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | If phone pc recognize phone as qualcom loader then u can repair dead boot via usb.......Just install correct drivers, download this file:https://dl.dropboxusercontent.com/u/71396908/galaxy_S4_9505%20boot%20repair%20QHUSB.exe ... Run the file as admin, select correct comport, and click on "recover device". After successful recovery u need to flash phone via odin with stock rom including PIT file. If u flash it without PIT phone will be dead again. Good luck. Post result here. Thanks to mr legija.... |
06-02-2013, 17:54 | #7 (permalink) | |
Freak Poster Join Date: Nov 2006
Member: 385979 Status: Offline Thanks Meter: 16 | Quote:
04-16-2014, 17:49 | #12 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2057646 Status: Offline Thanks Meter: 1 | S4 Dead boot repair I can't understand how it works. I have about 20 PCB with no power on error and for all value is between 0,05 A ~ 0.07 A. I installed QHUSB driver, connect phone to pc, pc recognizes port. Start program galaxy_s4_I9505 boot , click Run -> a cmd windows appears for 3-4 sec finish and closes, what do I do after ???? Phone is still dead, same current !! |
04-16-2014, 18:39 | #13 (permalink) | |
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | Quote:
sent from my Xperia Z1 using Tapatalk 2. | |
04-17-2014, 01:05 | #14 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
So,Please check every PCB via RIFF box for Check eMMC Chip if eMMC Can't detect via DCC Loader,You need replace if eMMC Can detect ,Please write latest working dump file | |
04-27-2014, 18:24 | #15 (permalink) | |
Member: 2057646 Status: Offline Thanks Meter: 1 | Quote:
So PC detect phone but after I lunch S4 boot repair CMD window appears some action there an closes. I will add screen shots. A friend told me that for PCB stuck at 0.5 A ~ 0.7 A it's due to PMIC. I will test and come back with answer. | |
