11-23-2014, 11:31 | #1 (permalink) |
Insane Poster Join Date: Jul 2011
Member: 1619960 Status: Offline Sonork: 100.1613623 Thanks Meter: 68 | I9505G Can not repair boot... help I have I9505G dead After wrong flash tried to resurrect via riff but box gave me this MSG Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I9505G V1.0.5053.51851] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x2071B0E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. Help me Riff Supporter thanks in advance |
12-07-2014, 12:32 | #2 (permalink) |
Member: 1619960 Status: Offline Sonork: 100.1613623 Thanks Meter: 68 | Two weeks no one answer Two weeks no one answer me !!! where is the RIFF supporters If they have any Solution tell me , if they don't have any solution they can answer me we have no solution. but i wait two weeks and the result no answer very bad support _________________________________ My problem solved Alhamdulillah |
12-07-2014, 19:41 | #4 (permalink) | |
Member: 1619960 Status: Offline Sonork: 100.1613623 Thanks Meter: 68 | my problem Was solved Quote:
i was tried all tck speed + full battery all things but no connection between box and phone but my problem Was solved when i Replaced USB cable with JIG | |
