09-18-2012, 19:43 | #1 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | I997 infuse ( E :failed to mount /dbdata ) and gives error.... Quote:
I tried flashing it with stock Firmware from **************** with odin, with pit without pit, Flashed with SPT, Z3x but still same. I think the last option is to write Full Dump from working phone. So does someone have I997 Full Dump please share. Or any other solution would be appreciated. | |
09-18-2012, 23:13 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Dump File Can't Help,Becase Your Phone Have a Fault Internall Storage... if You want repair phone,You replace eMMC Chip -------------------- Please Make Sure About Phone Model and Make Sure About Correct Firmware |
09-19-2012, 07:06 | #3 (permalink) |
Member: 821646 Status: Offline Thanks Meter: 507 | Thanks for the reply Im sure that it's not hardware problem as the phone was in working condition the customer tried to flash custom ics firmware on it and thereafter phone stuck in this condition. And i'm sure about the model and the firmware i'm flashing. |
09-19-2012, 11:06 | #4 (permalink) |
Member: 821646 Status: Offline Thanks Meter: 507 | Problem solved PRODUCT SUPPORTERS PLEASE RESEARCH FOR THE PROBLEM AND THEN TRY TO PROVIDE A SOLUTION. My problem solved by just flashing I997UCKE4 firmware. I was just going to kill my phone trying to replace its eMMc chip. Thank G O D i tried flashing this firmware before trying BABAK_NURI's advice. This is not to be rude on the riff team but one should try to first learn the problem himself. This could save or even destroy someones phone. |
The Following User Says Thank You to CDMA_RASHID For This Useful Post: |
09-19-2012, 11:41 | #5 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You Say : Quote:
------------------------ Also,Phone never can't kill by replace eMMC.... | |
09-30-2012, 14:38 | #6 (permalink) | ||
Freak Poster Join Date: Mar 2005 Location: india Age: 55
Member: 125424 Status: Offline Thanks Meter: 21 | same same happened to my i997 Quote:
pls..................... Quote:
as my set was ok just trying to upgrade, set boot was dead while flashing, boot was recoverd with riffbox ( thx to riff ) but now stuck in recovery mode HELP NEEDED URGENTLY thx | ||
10-01-2012, 00:30 | #7 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
if you did search,you can find only in 10sec.... -- Try This: Hotfile.com: One click file hosting: SGH-I997_I997UCKI4_UC_ATT.rar -- i think "E" version,is a OTA update | |
10-01-2012, 09:59 | #8 (permalink) |
Member: 125424 Status: Offline Thanks Meter: 21 | yes have tried Hotfile.com: One click file hosting: SGH-I997_I997UCKI4_UC_ATT.rar but not helped tried other versions also but same stucked on recovery any other idea !!!!! |
10-02-2012, 12:17 | #9 (permalink) |
Member: 821646 Status: Offline Thanks Meter: 507 | I997UCKE4 Was downloaded from SPT support section and was in .spt format. And is meant to be flashed with SPT box. Flashing with original flasher didn't helped me. Just download this firmware from SPT support and flash it with SPT software. |
10-09-2012, 20:17 | #11 (permalink) |
Member: 125424 Status: Offline Thanks Meter: 21 | hi............. thx CDMA RASHID dear i have done it with Odin_UCKE3_v2 set is working again perfect... tried twiced 100000%%%%%%% its simple software solution |
10-21-2012, 18:48 | #13 (permalink) | |
Junior Member Join Date: Oct 2007
Member: 607584 Status: Offline Thanks Meter: 0 | Quote:
10-21-2012, 23:51 | #14 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Usually : **************** ---- Other Firmware 2.2.1 Hotfile.com: One click file hosting: SGH-I997_I997UCKH1_ATT.zip |
