06-03-2018, 12:30 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: tizi-ouzou
Member: 432585 Status: Offline Thanks Meter: 24 | j110h resurrection complete but not power on complete but not power on here is emory info: Memory Type .......................... eMMC Manufacturer ID ...................... 0x90 OEM/Application ID ................... 0x4A Product Name ......................... "H4G2b " Package .............................. BGA User Area Partition Size ............. 0x0000E9000000 Bytes (3.64 GB) Boot Partition Size .................. 0x000000400000 Bytes (4.00 MB) RPMB Partition Size .................. 0x000000400000 Bytes (4.00 MB) OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) Write Protection Bits ................ NONE ExtCSD Register Fields ............... [177] = 0x00, [179] = 0x08, [162] = 0x00 Boot Configuration ................... Boot from Boot Partition 1 (Bus Width = 1Bit) Chip Revision ........................ 0.1 Multimedia Card Revision ............. 1.6 (eMMC v4.5, v4.51) Serial Number ........................ 0xBE43B0E5 Memory Manufacturing Date ............ November, 2015 please what is the solution to revive the phone |
06-04-2018, 10:49 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Most probably phone needs emmc replacement. Many times these models have problem with emmc, where data is accepted, but actually nothing can be written. Usually happens after phone freezes and firmware updated - emmc gets erased but no data stored. |
06-04-2018, 11:43 | #3 (permalink) |
Member: 432585 Status: Offline Thanks Meter: 24 | when resurrection complete it mean phone will power on ? when resurrection complete it mean phone will power on ? in my case j110h reserector will this fit all j110h phones or it's possible maybe the boot mismach? or the big probabilité emmc is dead if there are possibilité to try othere thing or forget the phone? thanks for reply ( by the way riff jtag manager stoped running when use plugin emmc based full image when clic on load layout from file this happen with me in 2 pc windows 7 this is my second problem) Last edited by heartfelt27; 06-04-2018 at 11:51. |
06-04-2018, 11:51 | #4 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | You can make simple test for start. 1. Make resurrection. 2. Read 256mb from user partition and save it 3. Open file in hex editor or better in emmc plugin and check if partitions contain data or is all zero If data is blank (00 00 00) it means emmc is bad. In any case I'd like to have look in such read out. |
06-04-2018, 13:17 | #5 (permalink) |
Member: 432585 Status: Offline Thanks Meter: 24 | how to set 256mb to read ? how to set 256mb to read ? i made a try like this check auto full flash size i got the fellowing error : WARNING: Resuming interrupted read from 0x000000000000, yet to read - 0x0000E9000000... Reading "User Area Partition" address space from 0x000000000000 to 0x0000E8FFFFFF ERROR: Read Failed with Error Code: (01:71). Terminating at 0x0000001C0000 i made another try like this checked use end adress, not length i got the fellowing error: Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 2.29V, SD_CLK Frequency is 960 KHz Detected eMMC Chip, ID: 0x90/0x4A (H4G2b ), User Area Partition = 0x0000E9000000 Bytes (3.64 GB) Requested area to read overflows current memory chip's boundaries. thanks for quick reply |
06-04-2018, 13:41 | #6 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | First, click "Check eMMC/SD Card" and save log. Then - simply select User Area, untick options on right and select 256mb from drop down list on data lenght: |
The Following User Says Thank You to legija For This Useful Post: |
