Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 08-30-2018, 04:28   #1 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
RIFF Box Qualcomm Sahara support, tips and tricks
Hello dear users !
We took some time to prepare latest addition to JTAG Manager and built from scratch complete Sahara protocol support (both firehose and streaming download). We didn't just embedded freely available tools from Qualcomm (emmcdl and qh_loader), instead, we used own code.
Great work is done on eMMC Plugin too, which now supports USB, ISP and JTAG access. You can select partition on LU (Logical Unit) to parse.
Among other improvements, we added GPT repair/adjust which serves as analogue to patch0.xml used with QFIL.
"Adjust GPT" will automatically update checksums and resize userdata partition to fill whole chip. This is valuable in cases where gpt is from different chip size.
There is more work, but we feel confident that current functions can satisfy most of the needs in servicing and forensics fields.
So, for start, few important tips:
1. Make sure to have Qualcomm drivers installed
2. Most Snapdragon 200 firehose loaders don't have read support, also some will not output storage info (size, SN, brand). We found out that there is one universal firehose looader which supports all this, but uses a bit different protocol. As this is Alcatel loader, we named it "Alcatel Firehose".
It can be used with MSM8x10, MSM8x12, MSM8x26 which otherwise don't have read support. File is attached here.
3. Sahara protocol requires phone to be in EDL mode. To enter EDL mode, exist few methods:
1. Kill phone BootChain or GPT
2. Switch to EDL from ADB or from TWRP: (TWRP tested on some Samsung models)
"Adb reboot EDL"
3. Use EDL cable (Xiaomi phones for example)
4. Activate Diag mode and JTAG Manager will switch it to EDL automatically if phone supports it.
5. Hold Vol+ for 10 seconds (OnePLus models)
6. Short EDL TP-s if exist
7. Short CMD to GND
9. Most reliable method is to remove eMMC
I'll add some videos to this post later, for now please test functionality and ask for clarification if there is anything unclear.
The Following 39 Users Say Thank You to legija For This Useful Post:
Old 08-30-2018, 09:51   #2 (permalink)
Member: 388862
Thanks Meter: 107
add oppo r15 sdm660 ,redmi note5 sdm636
Old 08-30-2018, 10:34   #3 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Hi,
If You have firehose loaders, simply select "external binary format file" as on screenshot. MCU model is irrelevant.
Old 08-30-2018, 10:46   #4 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
where is loader file? you mentioned as universal
Old 08-30-2018, 11:19   #5 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Redmi Note5 Pro is SDM636. Firehose loader should be embedded with firmware.
Give me some time to check it.
Oppo R15 we haven't tested, but loader is there in ops file. Need to decrypt it, also need some time (few hours).
The Following 2 Users Say Thank You to legija For This Useful Post:
Old 08-30-2018, 11:51   #6 (permalink)
legija's Avatar
Member: 256342
Sonork: None
prog_emmc_ufs_firehose_Sdm660_ddr.elf
prog_emmc_ufs_firehose_Sdm636_ddr.elf
The Following 3 Users Say Thank You to legija For This Useful Post:
Old 08-30-2018, 12:41   #7 (permalink)
otherboy123's Avatar
Member: 2006794
Sonork: 100.1664636
Thanks Meter: 164
very nice update king jtag box i want to test now. Good update love u team.
Old 08-30-2018, 13:47   #8 (permalink)
Member: 349359
Thanks Meter: 7
i have lg v20 dead with ufs chip , can i revive it . it battery charging sign when battery charge is low but vibrates alone with black screen when battery is charged. can i fix it with this update.
Old 08-30-2018, 13:59   #9 (permalink)
Member: 694980
Thanks Meter: 91
support to
Moto X4 XT1900-6
Samsung S6
USB support?
Old 08-30-2018, 17:47   #10 (permalink)
Member: 1034743
Sonork: 100.1619212
Thanks Meter: 193
Riff box is good,,but team slowly worked..
i hope also update this device regurarly
look like z3x jtag , octoplus jtag , medusa etc
Old 08-30-2018, 20:16   #11 (permalink)
Saffu~A.'s Avatar
Member: 1531030
Sonork: Yahoo_Akm
Thanks Meter: 118
excellent update you are great Riff Team............
The Following User Says Thank You to Saffu~A. For This Useful Post:
Old 08-30-2018, 21:57   #12 (permalink)
Member: 2319200
Thanks Meter: 5
Best team for jtag well done
Old 08-31-2018, 05:33   #13 (permalink)
Member: 331917
Thanks Meter: 214
Originally Posted by legija View Post
Hello dear users !
"Adb reboot EDL"
7. Short CMD to GND
Sir, could you please privide HEX data to do it via diag??
I tried 3A, but no luck.
http://forum.gsmhosting.com/vbb/f83/...-mode-2461092/
thanks
Old 08-31-2018, 07:33   #14 (permalink)
legija's Avatar
Member: 256342
Sonork: None
thanks
4B 65 01 00 54 0F 7E
Of course DIAG or manufacturer mode must be enabled first, and of course not all models will comply.
I've tested Huawei few models and they all go to EDL via this, but on LG some do, some not.
The Following User Says Thank You to legija For This Useful Post:
Old 08-31-2018, 16:26   #15 (permalink)
Member: 331917
Thanks Meter: 214
Thanks Sir, I tried on motorola xt1789 and didnt work
thanks anyway for your help
The Following User Says Thank You to Nicogalan For This Useful Post:
Page generated in 0.22108 seconds with 9 queries
