Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 02-14-2011, 11:03   #16 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
* * * RIFF JTAG -Atmel, Broadcom, Marvell, Qualcom Generic NAND DCC Loaders * * *
Hi,
This is latest update for RIFF JTAG owners.
  • MSM6XXX L06 D02
  • MSM7XXX L41 D04
  • MSM7XXX L41 D08
  • QSD8XXX L41 D04
These DLL-s contains only DCC Loader, thus it is to be used only for operations on DCC Read/Write page in the JTAG Manager.
Embedded DCC Loaders are designed to work inside of MCU's internal RAM memory, thus it is not sensitive to external SDRAM configuration or availability or its physical state.
This will enable You to work with wider variety of devices, based on QC CPU-s then usual model restricted DLL-s.
Initial H/W init sequience will setup MCU's PLL0 with these parameters:
  • L/M/N = 0x41/0x00/0x01;
  • Global Clock Divisor = DIV4
If you don't know what the L, M, N or Global Clock Divisor parameters are, then just keep in mind:
  • Highest L values and lowest Global Clock Divisor values will make maximum clocking frequency supplied to the MCU's core and thus DCC Read/Write speed will be maximum fast;
  • Too high frequency supplied to the MCU's core may result in core overheating or instable operation;
Once You download these DLL-s, You'll have new brand group in models list:
So, to summarize, You can use these DLL-s together with Qualcom Partition Tool plugin, with devices where specific brand/models DLL will not work.
The Following 21 Users Say Thank You to legija For This Useful Post:
Old 02-16-2011, 16:01   #17 (permalink)
legija's Avatar
Member: 256342
Sonork: None
16.02.2011 - Qualcom QSC6xxx DCC Loader released
Resurrector QSC6XXX L36 D08 contains only DCC Loader, thus it is to be used only for operations on DCC Read/Write page in the JTAG Manager.
Embedded DCC Loader is designed to work inside of MCU's internal RAM memory, thus it is not sensitive to external SDRAM configuration or availability or its physical state.
Initial H/W init sequence will setup MCU's PLL0 with these parameters:
  • L/M/N = 0x36/0x00/0x01;
  • Global Clock Divisor = DIV8
The Following 7 Users Say Thank You to legija For This Useful Post:
Old 02-16-2011, 16:43   #18 (permalink)
legija's Avatar
Member: 256342
Sonork: None
16.02.2011 AT91SAM9263-EK board NAND Interface supported :
Resurrector AT91SAM9263-EK contains only DCC Loader, thus it is to be used only for operations on DCC Read/Write page in the JTAG Manager.
Embedded DCC Loader is designed to work inside of ATMEL AT91SAM9263 MCU's internal RAM memory.
Loader has full (read/write) access to AT91SAM9263-EK evaluation board's NAND memory.
Currently only the 8-bit NAND interface is implemented.
Some people use this evaluation board to read various NAND chips content.
Old 02-18-2011, 15:34   #19 (permalink)
legija's Avatar
Member: 256342
Sonork: None
JTAG Manager 1.25
- improved again the DCC flashing functionality (for DCC Loaders that work in targets with a small RAM capacity);
- (SDK): added condition when resurrectors can order to bypass ID check;
The Following 2 Users Say Thank You to legija For This Useful Post:
Old 02-18-2011, 15:34   #20 (permalink)
legija's Avatar
Member: 256342
Sonork: None
JTAG Manager 1.26
- added MDOC G4 NAND chip size to auto flash size detection list;
- (SDK): more functions are now available (exported) for future Resurrector DLLs;
Old 03-04-2011, 12:56   #21 (permalink)
legija's Avatar
Member: 256342
Sonork: None
04.03.2011 Qualcom Generic NAND ESM7xxx DLL released
Resurrector ESM7XXX L41 D04 contains only DCC Loader, thus it is to be used only for operations on DCC Read/Write page in the JTAG Manager.
The Following 3 Users Say Thank You to legija For This Useful Post:
Old 03-10-2011, 13:50   #22 (permalink)
legija's Avatar
Member: 256342
Sonork: None
10.03.2011 QUALCOMM QSC60XX Generic DLL-s
Resurrector QSC60XX L24 D08 contains only DCC Loader, thus it is to be used only for operations on DCC Read/Write page in the JTAG Manager.
Initial H/W init sequence will setup MCU's PLL with these parameters:
  • L/M/N = 0x2A/0x00/0x01;
  • L/M/N = 0x20/0x00/0x01;
You can use these two DLL-s with all QSC6xxx CPU devices with NOR flash.
(Any CDMA phones with Qualcomm QSC60xx CPU, with NOR flash chip)
The Following 12 Users Say Thank You to legija For This Useful Post:
Old 03-10-2011, 14:05   #23 (permalink)
legija's Avatar
Member: 256342
Sonork: None
10.03.2011 RIFF JTAG Manager v1.27, RIFF Box Firmware v1.19
Whats new :
  • Fixed access violation bug upon JTAG Manager startup if there is no RIFF Box detected and Cancel button is clicked.
  • (SDK): more functions are now available (exported) for future Resurrector DLLs;
  • Added flags for JTAG Manager to be able to retrieve memory chip size from the DCC Loader.
  • Fixed initialization bug for NOR-related DCC Loadererss
  • ScriptEngine: added options pocessing ‘/byte’, ‘/word’, ‘/long’ to data.save.binary instruction: thus it’s possible now to read memory through script using desired bus access width (8-,16-, or 32-bit widths). For example: “data.save.binary c:\myfile.bin 0×00..0x11FF /word” – will read 0×1200 bytes from memory into myfile.bin file starting from address 0×00 using 16-bit bus accesses.
Note: “Read Memory” button on the JTAG Read/Write page reads memory using 32-bit bus accesses only.
  • Added more H/W script (*.has) instructions;
  • Added HTC security processing functions;
Please click “Check For Updates” button in order to download and apply new files. Closing all running application before starting update process is recommended.
The Following 15 Users Say Thank You to legija For This Useful Post:
Old 03-14-2011, 16:34   #24 (permalink)
legija's Avatar
Member: 256342
Sonork: None
14.03.2011 RIFF Box JTAG Manager v1.28, RIFF Box Firmware v1.20
Whats new :
JTAG Manager 1.28
- added RAM selft-test right before uploading DCC loader.
- added functionality to handle complex memory devices (like MDOC H3) with lengths not necessary to be alighned to MBs;
- added DCC TX channel flushing command before starting DCC Loader - thus it is guaranteed that next first DCC read will get DCC Loader's packet
and not some residual trash data.
- added 1GB and 2GB OneNAND chips to the size autodetection list.
- added progress indication during saving files which were read on the DCC Read/Write page
Firmware 1.20
- optimised connection to the PXA270 core
- added DCC TX channel (host-to-debugger) cleanup (flushing) feature (happens now during DCC Read with 0 timeout parameter)
for Cortex-A8
- optimized Cortex-A8 connection establishment after coming out of reset (after NRST signal assertion)
- added emergency script processing for Cortex-A8 core (h/w script which is executed immediately after core was halted)
Old 03-21-2011, 14:08   #25 (permalink)
legija's Avatar
Member: 256342
Sonork: None
21.03.2011 - RIFF Box Firmware v1.21
Firmware 1.21
- added RX-polling feature (debugger-to-target) for PXA3XX DCC transfers.
RIFF BOX firmware is able now to wait (if resurrector DLL will request so) for PXA3XX target to be ready to accept
next packet over DCC: this feature slows down a little the JTAG-to-Target DCC
transfers but guaranties no packets loss for slow clocked targets;
The Following 6 Users Say Thank You to legija For This Useful Post:
Old 03-21-2011, 14:19   #26 (permalink)
legija's Avatar
Member: 256342
Sonork: None
21.03.2011 MARVELL PXA3XX NAND Generic DLL Released
Resurrector PXA3XX contains only NAND DCC Loader, thus it is to be used only for operations on DCC Read/Write page in the JTAG Manager.
Old 04-06-2011, 11:03   #27 (permalink)
legija's Avatar
Member: 256342
Sonork: None
06.04.2011 CDMA QUALCOMM QSC1100 Generic DLL released
Resurrector QSC1100 X14 contains only DCC Loader, thus it is to be used only for operations on DCC Read/Write page in the JTAG Manager.
Embedded DCC Loader is designed to work inside of MCU’s internal RAM memory, thus it is not sensitive to external SDRAM configuration or availability or its physical state.
Initial H/W init sequence will setup MCU’s PLL with these parameters:
  • Clock Multiplier = 0×14
Since few different versions of QSC1100 resurrector may exist (with different multiplier values) you may select the one which suits best to your device.
Old 04-06-2011, 12:28   #28 (permalink)
legija's Avatar
Member: 256342
Sonork: None
06.04.2011 QUALCOMM NOR QSC60XX L18 D08 Generic DLL Released
Resurrector QSC60XX L18 D08 contains only DCC Loader, thus it is to be used only for operations on DCC Read/Write page in the JTAG Manager.
  • L/M/N = 0x18/0x00/0x01;
Since few different versions of QSC60XX resurrector may exist (with different L or Global Clock Divisor parameters) you may select the one which suits best to your device.
Old 04-08-2011, 17:13   #29 (permalink)
legija's Avatar
Member: 256342
Sonork: None
08.04.2011 Generic Broadcom BCM2156 OneNAND DLL Released
Resurrector BCM2156 OneNAND 4K contains only DCC Loader, thus it is to be used only for operations on DCC Read/Write page in the JTAG Manager.
Current DCC Loader is designed to work only with OneNAND devices which have page size 4096 bytes.
The Following User Says Thank You to legija For This Useful Post:
Old 04-12-2011, 10:47   #30 (permalink)
legija's Avatar
Member: 256342
Sonork: None
12.04.2011 RIFF JTAG Manager v1.30, RIFF Box Firmware v1.22 released
Firmware 1.22
  • Fixed bugs in ARM7 core handling routines
JTAG Manager 1.30
  • Added DISABLE_POLLING request processing from DCC Loader
(used by DCC Loaders which have small RAM size available and there is no DCC RX polling is implemented in RIFFBOX firmware for current core);
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.27955 seconds with 11 queries
